The lion passant symbol, lion looking left with a front leg raised is the standard symbol for silver. It means silver content is 925/1000. Could the 12 be an M? Numbers here are not the norm. Letters are more common. M being the mark for Tiffany.
WHAT KIND OF CRANKING PRESSURE DO YOU HAVE? MORE THAN LIKELY, YOU WILL NEED COMPRESSION RELEASES IF YOU ARE NOT RUNNING A STOCK MOTOR. CHANGING YOUR RING GEAR WILL ALSO HELP A LOT. PRIMO RIVERA AND I'M SURE OTHERS HAVE THE RING GEAR YOU NEED. IT HAS LESS TEETH THAN THE STOCK RING GEAR. I RUN A 116'' S&S TWIN CAM WITH 210 LBS CRANKING PRESSURE. I HAVE AN ODDESY 925 CRANKING AMP BATTERY WITH S&S COMPRESSION RELEASES AND THE PRIMO RING GEAR. NO MORE PROBLEMS. PHONE NUMBER, 714-624-1915 NAME'S JAN.
