Question about iLO Televison & Video
I need a reference ILO HD TV Model 2600 cabling diagram?
I am in possessin of an ILO MOdel 2600 HD TV which had been messed with by the previous owner. I am missing a very small cable connecting teh processor board to the operator push button arrangement.
Posted by Doni Witt on
5 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
Anonymous
SOURCE: ilo 27inch hdmi hd tv monitor
You would need to connect a VGA + Audio to HDMI Converter. The downsize it the converter goes for about $150 us
Posted on Apr 12, 2008
res116
SOURCE: Part # for a Y Sustain Board Cable Ribbon
why are you replacing it? what went wrong? mine just stopped lst nite and jsut ties to turn on. email [email protected]
Posted on Jun 18, 2008
Anonymous
  • 62 Answers
SOURCE: CONNECTING MY TV TO MY STEREO
Make sure the output in your tv menu is set to external speakers. Any digital optical cable, or RCA jacks hooked up properly from the TV's out put to the receivers input should work just fine. Take your time, retrace your steps, and make sure each cable is in the correct input/output. And make sure the receiver and TV are on the proper settings. Good Luck, and thanks for using FixYa!
Posted on Jan 13, 2009
Anonymous
SOURCE: I am Unable to connect my Aduio cables from the xbox 360 to my TV
1) Connect the red, white & yellow audio leads in to the 360 scart adapter and then plug this in to the scart socket on the tv
2) change the xbox 360 selector at the back of the console from HD to TV
2) Select the input of scart on the tv
You should now get pictures & sound.
Posted on Jan 31, 2009
Need tv codes for one for all remote for ilo tv
try to be specific : Brand and model of your remote control.
Sep 12, 2009 | iLO 2600 Television
Need a remote
Here's one place to get the remote for the TV;
http://www.remotes.com/store/ilo/rc-2600-ilo.html
The Directv web site has only one code to try for the ILO TV. 10171
Does that code work on the TV?
May 11, 2009 | iLO 2600 Television
Need dc cord
try radio shack,if they dont have it 6hey should know how to find it,good luck
Apr 21, 2009 | iLO 2600 Television
ILO universal remote code
Buy an rca universal at wal mart (model rcr312w) $8.00 fix.  Just follow the Auto Scan instructions, it worked for my 26" ilo today.
Jan 21, 2009 | iLO 2600 Television
ILO 26" LCD HDMI TV
I had the same problem at first. Then I went back to fry's and bought a new DVI cable. Make sure you bought the right one.
Nov 25, 2007 | iLO 2600 Television
Dish network box hookup question.
Are you sure that the antenna in isn't threaded? You may be looking at the wrong jack... All antenna inputs are threaded co-axial "F" connectors. If you ARE sure, could you post a pic of the back panel?
Sep 12, 2007 | iLO 2600 Television
Ilo 26" lcd tv
is it the ilo2600 model or ilo26hd
Feb 05, 2007 | iLO 2600 Television
Televison & Video Logo
54 people viewed this question
Top iLO Televison & Video Experts
Lee Hodgson
Lee Hodgson
CoppellTVRepair.com
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
