SOURCE: Loaded 3D Embroidery software on
Try to install the software from the download as its latest version its will prompt you to remove the old version on your computer and follow onscreen instruction you be able to install the software...........
SOURCE: janome customiser 11000
When you backed up you probably only backed up documents. The executable files that make the program work are in program files and folks seldom back up program files. It was pre-installed on your pc? How weird. I believe the only thing you can do now is to go buy Customizer 11000. Check ebay and the yahoogroup sewitsforsale to see if there are any used copies. It's not an expensive program, and frankly, you don't NEED it if you have Embird, which does all Customizer does plus more.
HTH
SOURCE: Looking for Dongle and Power Cord for Memory Craft Digitizer 2000
The only way to get a new dongle for your software is to purchase a new software package.
You can call Janome and ask them ... but I'm 99.9% sure that they'll tell you the same thing. :(
SOURCE: Digitizer 2000 - Dongle ?
I'm going to assume that you mean the Digitizer 2000 software.
Unfortunately, your best bet will be to either wait and see if another copy (complete with dongle) shows up on eBay or upgrade to the Digitizer 10000 version (while Customizer 10000 is NOT compatible with the MC9000, Digitizer 10000 IS), either via your local dealer or snagging it on eBay.
Right now, there's two auctions on eBay for the Dig 10000. It seems to run roughly around $300-400.
Best of luck to you!
SOURCE: Loaded autodigitizing onto our new computer with
There is an update for dongles and windows 7.
Info on Husqvarna Viking website - http://www.husqvarnaviking.com
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
Link to dongle drivers - http://www.vsmsoftware.net/downloads/HASP/haspusersetup.exe
Good luck.
