Question about KitchenAid Food Mixers
Kitchenaid mixer: When reattaching the planetary, the motor shaft is pushed up 1/8 thus the retaining pin cannot be installed. Gears are aligned
Posted by don mcfall on
Ross Keen
  • KitchenAid Master
  • 1,364 Answers
I make sure that the hole in the shaft is going to be in alignment with the hole in the planetary before offering the planetary up. Once it's on as far as it wants to go I encourage the planetary up as much as possible with a soft face mallet. Once you have it up that far you can normally see the beginning of the shaft hole if you look into the planetary hole. I have a thin very pointed stainless steel scriber that tapers all the way from pin size to the size of the hole. For me it's just then a matter of jiggling it about to with the scriber to make the 2 holes line up.
Posted on Sep 17, 2018
5 Related Answers
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: I have a Kitchenaid Professional
I would give the "accept" to bestdarngood , if I were you..He has given the bets and complete solution there...That should work, if it doesnt. the the only recourse is a service center..
Posted on Jun 28, 2008
Anonymous
hi
there is a ring clamp on top of the main worm follower gear on the drive shaft. you might not see it due to the grease.
you need to get one of those weird little pliers with points on them to spread the ring clamp to remove it. Then the gear is just friction fit on the shaft...it's pretty tight. I carefully used a screwdriver to slowly separate the main follower gear from the lower gear and it goes up the shaft....
after a bit you can wiggle the follower gear by hand and it will come up. Then you can see there is a pin holding the drive gear underneath it in place. The pin in my mixer was actually bent (must have been some tough dough).
then you reverse the process to put the gear back on -- except that the top follower gear has to go on the pin in the right orientation or the ring clamp won't fit.
buy your parts from mendingshed.com
hope it helps.
Posted on Aug 25, 2008
Anonymous
  • 41 Answers
SOURCE: Hobart N50 / KitchenAid Model G: how do i remove planetary?
you need to remove all the back screws then if it doesnt come tap it with arubber mallet it may be seized on
Posted on Dec 09, 2008
Anonymous
  • 110 Answers
SOURCE: hi somenone may describe how I can procede step
after you removed the tapered pin on the plant. you should be able to get it off the mixer main shaft @this point, there is nothing else holding it to the main shaft
Posted on Jan 16, 2010
Anonymous
  • 53 Answers
SOURCE: kitchenaid professional 6 stand mixer: planetary falling off
http://www.fixya.com/support/t3235959-planetary_fell_out_while_mixing_bread
Posted on May 31, 2010
How do I reattach a planetary that was pulled off?
I haven't seen enough of that model to remember, look up a local service agent and ask them is probably your best option. Whoever does the warranty repairs for Kitchen Aid would be the best person.
Dec 18, 2015 | KitchenAid KP2671 Professional 6 Series...
How to replace motor in kitchenaid artisan mixer
Sounds like a worm gear problem to me, it's impossible for the motor (armature) to move far enough to not drive the gear. There are driving pins in the system from fuse gear to paddle.
1) in the fuse gear
2) inside gearbox above planetary joining shaft to bevel gear
3) through planetary and shaft
There is also one joining the little gear inside the planetary to the shaft, doubt you'd break that one though.
Jun 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
How to remove stuck bevel gear off planetary shaft in KitchenAid 6qt professional mixer
That should just lift off, I'm not familiar with your particular model but all the bevel gears I have seen just drop onto a pin that is just a push fit through a hole in the shaft.
Oct 26, 2013 | KitchenAid KP26M1X Stand Mixer
Kitchenaid mixer leaking oil
Get a copy of the Repair Part List for your model at Kitchenaid.com
Grease inside the Planetary Assembly (the shaft is tight fit to the Planetary
plate at the factory and is not designed to be taken apart, so do not use
any hard object such as a screwdriver to separate them) over times can
turn to liquid and leak down the bowl. Removing the Planetary assembly
and adding Kitchenaid Food Grade Grease is not a task for a novice.
To properly remove the Planetary Assembly, you must work from inside
the Transmission Housing: Remove in this order: Retaining Clip(25), Bevel Gear(21),
Retaining Pin(18), Worm Follower Gear(19). Use a soft mallet to tap out the Shaft
of the Planetary Assembly(15). Re-assemble it in the reverse order.
Note: The Bevel Gear is extremely tightly fit on the shaft, and a pin punch
must be used to remove from the shaft.
Jul 14, 2011 | KitchenAid KP2671 Professional 6 Series...
KitchenAid food processor makes a grinding/clunking noise while running. (Not supposed to be there.) Sounds like gears not aligned.
It is most likely a stripped gear. Here is a link to the parts manual which contains the listing of the gears and shows you how to split the gear case.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212057.pdf
Remove the chrome ring with a screwdriver by prying it off carefully. This exposes 5 screws, however they can't be accessed on all models. Remove the pin (17) that goes through the planetary housing and the drive shaft, and carefully drive the planetary housing from the shaft to expose the screws. Then remove the two remaining screws and split the case to expose the gears. The worn gears will be obvious. Also check the bearings. Replace all affected parts. Remove all grease since metalic pieces will have contaminated it from any worn out gears. The grease is a special food grade grease which you can purchase along with the gears and bearings.
Apr 06, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
The planetary mechanism (gear, plate, etc) on my 6Qt. 575Watt KitchenAid seems to have fallen more than a half inch along the main axle leaving a gap between the 'plate' and the bottom of the mixer head....
It appears that retaining ring (7) has snapped. It is the retaining ring which attaches to the drive shaft. Here is the parts diagram:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10157992.pdf
From it you can see how to remove the case cover and access the gear train. You may have to replace the shaft if its groove is worn allowing the retaining ring to slip off.
Apr 05, 2010 | KitchenAid KL26M8XOB Stand Mixer
I have a Kitchen Aid Professional 600, 6QT, 575 W mixer. I went to use it and the beater and the assembly that it attaches to dropped down in my mixing bowl! What holds this assembly up? I did not find any...
Hi DASCO474. This is not good... From the symptoms you describe your mixer’s Agitator shaft is dropping from the Planetary assembly. Something has caused the retaining clip and pin to break so allowing the agitator shaft to drop.
Fortunately the inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case: KP26M1, and select one of the first two files listed under Parts List (47) (The first file, KP26M1XAZ4.pdf (304.18 KB), is for a -4 series model and the second file, KP26M1XAZ5.pdf (724.41 KB) is for a -5 series with slightly different insides, so make sure you have the correct Parts List manual.)
Turn to pages 4 & 5 entitled “Case, Gearing And Planetary Unit” for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 28, Planetary Assembly and Illus. No. 34, Agitator Shaft. The parts which hold the Agitator Shaft within the Planetary are Illus. Nos. 9, Retaining Pin and 30, Retaining Clip. I suspect these parts have failed and will need to be replaced. Now the real fun begins!
To get to the Agitator Shaft gear you’ll need the following tools: a regular or Phillips screw driver, retaining clip pliers, and a small drift pin punch and a small hammer. After removing the Gearcase Motor Housing (mixer top) you will need to remove the Transmission Housing (Illus No. 4) and remove all the lubricating grease from the transmission housing and gears. This will allow you to remove Illus No. 7, 8, 9 & 10, Retaining Clip, Bevel Gear, Retaining Pin and Worm Gear Follower, respectively.
Once you remove the Retaining Pin (Illus. No. 9) the Planetary Assembly can be tapped down through the Lower Gearcase Assembly (Illus. No 11). With the Planetary removed, you should find all the parts which slide on the Agitator Shaft (Illus. Nos. 30, 31, 32, & 33) and pieces of the retaining pin, which should be loose in the base of the Planetary.
Besides ordering a new retaining pin and clip, you might want to reorder the Transmission Cover Gasket (Illus No. 6), too. You’ll also need to replace the grease you removed with new grease. Do not try to reuse any original grease as it may have ‘debris’ in it. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
With your mixer apart and the grease removed from the gears you can check for any other unseemly wear and tear on the gears, too.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, determine what’s wrong, order the correct parts and reassemble your mixer.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Feb 03, 2010 | Food Mixers
HOW DO YOU REMOVE THE PLANETARY ON A KITCHENAID MIXER MODEL KP26M1XGR3
Hi DAVE, Merry Christmas & Happy New Year! The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case: KP26M1, and select one of the first two files listed under Parts List (47) (The first file, KP26M1XAZ4.pdf (304.18 KB), is for a -4 series model and the second file, KP26M1XAZ5.pdf (724.41 KB) is for a -5 series with slightly different insides, so make sure you have the correct Parts List manual.) (For the purpose of this solution I will use the 5 Series Parts manual. Substitute accordingly if you have a 4 Series model.)
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts.
(1) Remove your KA Decorative Trim Band (Illus No. 3) by removing one (1) screw (Illus No. 22).
(2) Remove the four (4) head cover screws (Illus No 14) and lift of the mixer head cover (Gearcase Motor Housing top, Illus No. 1).
(3) Next, remove the two (2) screws (Illus. No. 14) securing your (Speed) Control Assembly (Ilus. No. 19) so you can move the Control Assembly out of the way. This will allow you better access to the Transmission Housing (Illus. No. 4).
(4) Remove the four (4) Transmission Housing screws (Illus. No. 14). Carefully lift the Transmission Housing off the base. The Transmission Cover Gasket (Illus. No. 6) may come off with the Hosuing or remain on the base. (Recommend reordering a new gasket if damaged)
(5) Remove all grease from inside the transmission cover and off all your gears. (This is the messy/fun part. While cleaning away the current grease, be sure to be keep and eye out for metal ‘filings’ that may be suspended in the grease.
(6) Remove the Worm Gear drive assembly (Illus. Nos. 16, 17, and 18) and set aside.
(7) Remove Retaining Clip (Illus. No. 7) from the Planetary shaft.
(8) Remove (lift up) the Bevel Gear (Illus. No. 8) from the Planetary shaft. This may require a little friendly persuasion, but it should eventually slide off the shaft exposing the Retaining Pin (Illus. No. 9).
(9) Remove the Retaining Pin. It should come out easily in either direction.
(10)You can remove the Worm Gear Follower (Illus. No. 10) but once the retaining pin is removed, you should be able to push the Planetary Assembly (Illus. No. 28) down through the Lower Center Bearing (Illus. No. 12). A few taps with a soft faced mallet may be required.
You now have access to the Planetary gear and Agitator Shaft Assembly (Illus. No. 34). Apply the same techniques to remove/replace any components from the Agitator shaft.
Assemble in reverse order above.
Continued in "Comments" - hslincoln
Dec 28, 2009 | KitchenAid K45SS Classic Stand Mixer
The rotating part of my mixer seems to have fallen out of place. When I push it up, it starts rotating but with a bad sound. What do I do?
Hi, MARITZALEW. You don’t indicate your specific KA mixer model, which limits the quality of the solution(s) I can offer, so I’ll start with a general solution. From the symptoms you describe, it appears that either 1) the agitator shaft (what you attach the beater blades to) is dropping out of the planetary, or 2) the whole planetary assembly is dropping from the mixer head.
The bad sound you hear when you attempt to push the assembly back into place is the gears protesting because the mixer is not operating normally. Continued operation in this manner could further harm the internal transmission gears, if not already damaged.
In either case, one of the retaining pins has probably failed and needs to be replaced. This is a job you can perform yourself, but it will be a little messy but very gratifying.
Do you have your mixer’s Parts List manual on hand? . If you're lacking one, you can download it from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number and select a file under the Parts List. (Check to see it this matches your mixer model). Turn to the pages titled: Case, Gearing and Planetary Unit, which provides an exploded view for the disassembly and reassembly of your mixer, along with all the parts.
Locate the Groove Pin on the parts list and then see where it is show on the exploded view. This pin retains the planetary/agitator shaft to the mixer head, and I suspect this is the pin that has failed and needs to be replaced. There is a similar pin which holds the agitator shaft inside the planetary. Getting to either pin will require the disassembly of the whole transmission. This will be messy as you will need to remove all the grease from the gears and center shaft.
Also, while your mixer’s apart you should check for any other unseemly wear and tear on the gears, etc. You may find more things that need replacement than just the groove pin.
Besides needing a replacement pin(s), grease, and possibly a gear or more, you might consider replacing the gasket, too. I recommend using a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should be search for ‘food grade grease’ if you start digging into the transmission. Prices can vary widely between vendors, so do your comparison shopping.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers may or may not be similar to your mixer, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good luck and have fun. I hope this helps. Howard, Burke, VA
Dec 13, 2009 | Food Mixers
Food Mixers Logo
471 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
