Question about Hotpoint Refrigerators
What is the temperature range on a Hotpoint freezer model 93423?
Posted by Jenny McCurry on
Kardoc
    Top Expert:
  • Hotpoint Master
  • 6,126 Answers
5 Related Answers
Anonymous
  • 9 Answers
SOURCE: hotpoint
This more than likely is because your evap.coil is frosted up do to a part failure with the defrost system. Look at the freezer back panel is there alot of frost growing all over it this is the number one sign. Either way take the back panel off and make a visual check. If there is alot of frost first get a multimeter and set it on Ohms with alert chime meaning you get continuity. First check the defrost heat if you get the chime sound from the meter or NOT a infinite number of Ohms then its good. Then look for the round shaped part hooked to the evap and in series to the heater this is the bimetal (while its good and cold) cut wires to it and strip ends and check for continuinty there also if so, it's good but must be frozen cold to get continuity wire nut it back after check if good. If those parts check out then your mechanical defrost timer is bad or adaptive defrost board is bad it would be either one depending on this model of fridge you have. Hope I helped.
Posted on Jan 23, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: oven temperature control intermittent
gas oven?? i would replacethe bake ignitor, the most common issue with unit not holding temp.
Posted on Nov 23, 2008
duby1990
Justin Duby
  • 370 Answers
SOURCE: Smell from fridge freezer
Put Charcole brickets in the refrigerator. Charcole works better than baking soda and usually take care of the smell.
Posted on Feb 20, 2009
peyton32034
peyton thompson
  • 410 Answers
SOURCE: I can not find the freezer temperature control
this model refrig does not have a seperate freezer control. the only control will be the refrig control. thanks peyton
Posted on Feb 26, 2009
Anonymous
  • 867 Answers
SOURCE: Hotpoint electric range (B747C) cooks slow
heating element needs to be replaced
Posted on Nov 25, 2009
Hotpoint Freezer rear airflow wheel adustment
It's a vent like the one in your vehicle
Service Information HOTPOINT SIDE-BY-SIDE FRIDGE ...
http://servicenet.indesitcompany.com > img_sm
PDF All models have wheels at the rear and wheels / adjustable feet at the front. ... The fridge and freezer temperature settings are adjusted by selecting the + / - buttons ... To allow product handling and sufficient air circulation, leave at least 10 mm ...
Operating Instructions - Hotpoint Docs
https://docs.hotpoint.eu > _doc > F088568_IFU
PDF It allows you to change the fridge temperature value, in a cyclical way; it also ... Do not obstruct the rear fan grills. The compressor ... If the floor is not perfectly horizontal, adjust the refrigerator by tightening or ... To avoid blocking the air circulation inside the freezer ... "wheeled bin" symbol on the product reminds you of your.
Where is the temperature control knob on Frigidaire upright freezer model #CFFH17F1RW
The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
How do I fix my refrigerqtor hotpoint double door not defrostiong
Generally, if you unplug the refrigerator and set the freezer and refrigerator temperature controls to off then plug it back it, this will put the refrigerator in forced defrost mode. Keep the doors closed and allow defrosting to last for about 20 minutes. Then unplug again and reset the temperature controls to mid-range or a little above, and plug it back in. If this does not reset the defrost cycle, you probably need service.
Cant find temperature control knob
Good Afternoon Friend,
I understand that you are looking for the temperature control knob on your Frigidaire freezer, model# FFU2064DW. The temperature control is located inside your freezer on upright models, and on the left outside wall on chest models. The temperature is factory preset to provide satisfactory food storage temperatures. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. Hope this is helpful.
-Best Regards-
WP
Hotpoint propane model rgb746hed2wh oven burner will not turn off, Digital reading f-2
F2
During BAKE, Control senses oven temperature above 615F-630F
f actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC). Here is the part to order.
1helpful
3helpful
2answers
Hotpoint rfs60 high temperature light staying on but freezer still works although maybe not to full potential
Had the same problem with the same model fridge, had to get the engineer out from hotpoint said it was the gases and their was a blockage in it. could not be fixed.
Smell from fridge freezer even after thorough cleaning and disinfecting and defrosting Model Hotpoint RFA52. Temperature control OK
Oven temperature control intermittent
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Dan Webster
Dan Webster
jdthefixer
Michael Thomas
Michael Thomas
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
