Question about Laser Office Equipment & Supplies
Practical ways laser jet p1102 can be maintained against damage and power surge
Posted by Edoho-ukwa Utuk on
1 Related Answer
pankaj_dic
pankaj rautela
  • 1252 Answers
SOURCE: Dear Sirs, if you can
change the cartridge then check
Posted on Jul 27, 2011
50.0 fuser error
SOLUTION: Follow the steps listed below:
  1. Turn the printer off and unplug it for 30 minutes; then turn the power back on.
  2. Try a different power cord. DO NOT use extension cords to plug the printer in.
  3. Remove the surge protector or UPS/CVT device and connect the printer directly to a power source.
  4. Try a different electrical circuit. There could be an issue with the line voltage going into the printer from the power source.
  5. Turn the printer off and unplug it. Let it sit for 30 minutes to let the fuser cool off. Carefully remove the fuser; IT MAY STILL BE HOT USE CAUTION. Examine the fuser, if any damage is apparent the fuser may need to be replaced. If no damage is noted reinstall the fuser, plug the printer back in and power it up.
For More info Source... Hp Error Code 50 Service Errors 50 Fuser Printer Repair
Thanks,
HP Printer Support
Jun 26, 2014 | HP LaserJet Pro P1102
Tip
How to troubleshoot 50.4 error message on printer?
The reason is as follows:-- A 50.4 error message on some of the newer HP Laser jet printer indicates a problem with the power supply.------------- If the printer is connected to a UPS, disconnect it, or disconnect it from a power strip and plug it directly into a wall outlet. A laser printer should never be plugged into a UPS, because the UPS can be damaged by the surges of power required by a printer to keep the fuser assembly warm. If that doesn’t work, make sure that all of the components in the printer are seated properly.this will help. thanks.good luck.
on Mar 05, 2010 | Office Equipment & Supplies
Tip
How to maintain your ink-jet printer
In the printer market there have thousands difference brands and models ink-jet and laser-jet printer, how can we eleminate their trouble to the minimon and extend their lifetime as long as we can. The paper tray for the ink-jet printer most are open top style, therefor very easy to catch dust and other cbject and cause paper jam, paper skew, paper rinkle, some cases are easy to remove some don't,when you have those case happen, the first thing you have to do is check the paper tray inside of the bottom , looking for somethings it not belong to, then clean up the paper feed roller with rubbing alcohol. Now how can we prevent it happen, the way is when finish printing use something to cover the tray. when paper jam occure, remenber, never pull the paper opposited way, you have follow the direction let he paper go forward, otherwise you going to damage the paper senser.
How about laser printer, the laser printer it's structure much stronger than ink jet s the cost much higher too, but their maintainence much easier, when it have paper jam occure, commonly replace paper pick up roller and paper stop roller, if you hear noise from back of the machine, 90% the fusing unit have problem, if the noise come from front, the problem almost in cartridge, the cartridge, here , I like to give you advise, use brand name cartridge better than generic one. because, too much manufacture, skill all difference as well as quality all difference, be careful, be smart !
on Dec 10, 2009 | Office Equipment & Supplies
P1102
power on printer after printer is in ready state press and hold down x
cancel button until ready flashes then release you will get config page
Jun 20, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
Hp laser jet p3015 not powering on
41.2 error hp laser p3015 printer
Mar 25, 2013 | HP Laserjet P3015X Printer
Scaner error 52 in my laser jet printer printer model :-hp laser jet 3052 all in one printer
52 Scanner Error
The all-in-one has experienced an internal hardware error.
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket.
3. Check the FFC connection between the formatter and the scanner.
NOTE Do not bend or fold the FFCs during the removal or reinstallation process.
4. Try connecting the product to a different power source or surge protector.
5. Turn on the power and wait for the all-in one to initialize.
6. If the error persists, replace the laser scanner assembly.
Jul 12, 2011 | HP LaserJet 3052 All-In-One Printer
Hi I have a Ricoh 1515MF and I recently had a power surge that fried my power strip, desktop and my Ricoh. The Ricoh will not turn on anymore. I have tried switching outlets, new power strips and nothing...
The power supply unit within the printer also would have damaged while the surge took place . The SMPS - the power supply - is quite sensitive to the power surge and so could have damaged the driver or the front end . you need to take a look at the SMPS unit to confirm. remove the power supply and check for fuse, if the fuse blows again then you have a problem in hand.
check the link for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Jul 07, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
Possible power surge?
Sounds like you got a surge which damaged the control panel. This is the most likely thing. We regularly repair these control panels nationwide for $32.50. A fuse is designed protect against excessive current. But if you have excessive voltage (a surge or spike), it can be so fast that it gets past the fuse and damages the control panel without actually blowing it. While the panel does have surge protection to keep that surge from actually destroying the control panel, the panel is damaged and will have to be repaired. If any power line connections were broken or are suspect, I hope you have contacted the power company. Either way, I would test any affected outlets to be sure the neutral and ground are present so the voltage output is within the proper range.
Nov 16, 2006 | Samsung MW5351G Microwave Oven
43 people viewed this question
Top Laser Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Barbat Nae
Barbat Nae
Scott Kalvinek
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
