Dead tv i have a sanyo Ds35590.will not power up.i can hear a faint wine'n sound from it????
Posted by bullvard on
  • 1 more comment
  • bullvard Nov 28, 2007
    it is a power supply problem.but i can not seem to find a new flyback for it. any help ??ds35590
  • bullvard Nov 30, 2007
    all i whant to know is can you still find a new flyback for this model i have looked every were
  • smithjohn70 Jan 11, 2008
    Same problem repaired horizontal went out again in a week repairman said could be flyback or something else knocking out the horizontal. Need schematic or service manual.
Anonymous
Please Check HOT (Q402)COLLECTOR AND EMITTER SHOULD NOT BE SHORTED. IF THEY SHORTED THEN REMOVE HOT AND CONFORM.
Posted on Nov 29, 2007
Anonymous
  • 3 Answers
Your tv needs a repair man near you, the problem is its malfunctioning power supply. I believe some electronic parts must be replaced.
Posted on Nov 25, 2007
Sanyo tv won't turn on after a lightning strike.
Ask friend if broken when given to you. If not I would suspect the power supply is fubar..
Sep 16, 2017 | Sanyo Televison & Video
No picture ,but i hear the sound
Dim the lights, turn on the TV and shine a bright light on the screen. If you see a faint picture, you most likely have a failed back light circuit. On your particular set, I belive the back light and the power supply are on the same board. I'm almost certain that board needs to be replaced but have the board checked before replacing.
Dec 16, 2012 | Sanyo DP42849 42 in. HDTV
Sanyo 35 tvmodel # DS35590 horizontal output gets hot
Maybe the flyback are in bad conditions or the ceramic capacitor near the output check him bott
Jul 24, 2010 | Sanyo Televison & Video
No picture, no sound.
contact sanyo, sounds like your display panel has gone bad
Sep 08, 2009 | Sanyo DS31590 31" TV
Sanyo tv ds35590 main board
that big wire is for the degauzing coil, connect it by plugging it to the main board near the power supply section.there are 2 terminal which is near to the thermistor.
Oct 20, 2008 | Televison & Video
Sanyo DS35590
It would be a little glass tube with a filament in it. To locate it you will have to take the back cover of your television off, follow the power cord up to where it connects. The fuse will be located very close to the power connection, look carefully.
May 13, 2008 | Sanyo DS31520 31" TV
Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
Jan 17, 2008 | Televison & Video
Sanyo DS35590 35" CRT Television
are you replacing the compasator PHE 820 M it is blue rectangle next to the fuse
Jan 14, 2008 | Sharp 27C-240 27" TV
Sanyo DS24425 TV Has No Picture and Very Faint Audio
DONT BUY SANYO ELECTRONICS THEY ARE JUNK
Jan 09, 2008 | Sanyo DS24425 24" TV
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
