Radio Communications Logo
Question about Radio Communications
I have a centrios Bluetooth phone/speaker.has phone pic on a button, volume up/down buttons. How do I pair it? no manual given with device. Has 1713165 & ic:2551-1713165
Posted by Shannon price on
5 Related Answers
Anonymous
  • 160 Answers
SOURCE: bluetooth syncing
Usually to solve some pairing problems shut off bluetooth completely(no lights) Push and hold button until bluetooth comes on,flashes then steady light,you may have to hold button for ten seconds or more.Then put phone in pairing mode.
When asked for pass code enter 0000.Phone should show connected to bluetooth device.
Posted on May 10, 2008
Anonymous
SOURCE: Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
  • press and hold MFB until indicator light flashes blue and red. The headset will also beep twice
  • to pair your device to the bluetooth headset use the bluetooth pairing instructions from you device's instrucition manual.
  • input ID code 0000 when requested by the device
  • the headset and device are paired correctly when the blue and red indicator light flashes blue only.
Any questions email: [email protected] Subject: omnitech bluetooth
Posted on Mar 09, 2009
Anonymous
SOURCE: Lost HTC BH M200 Bluetooth headset manual, How do I pair it?
Hi, to pair this device first make sure it is powered off.
Then press and keep holding the power on button (large round one on the front). After a few seconds the LED will illuminate blue and then after a couple more seconds will flash red and blue. Now you should be able to pair with it.
Regards,
Nik.
Posted on Nov 04, 2009
Anonymous
SOURCE: I have a centrios bluetooth
Pairing: Ensure speaker phone is off.
press and hold the MFB button for 5 seconds until LED blinks orange and unit announces "pairing mode on".
Go to the bluetooth section of your mobile phone and search for a new device. Once found "Centrios 1713165" follow the phone steps and enter 0000 to pair. Speakerphone is ready for use once it announces phone is ready. It should pair everytime it gets in proximity to the phone.
Posted on Sep 16, 2010
Anonymous
SOURCE: I have a Centrios Bluetooth.
Hold down the power button. Keep holding it after it says power on. A second or two later it will say pairing mode. Then you can have your blackberry search for it.
Posted on Jan 27, 2011
2answers
How to pair Craig CHT729 speaker to my phone please?
Pairing Bluetooth Devices
Posters often ask "How do I pair my Bluetooth ???" Insert whatever device you have at the question marks.
Generally, you need to read the instructions for the camera, headset, speakers or whatever the Bluetooth device is.
Roughly speaking though.
Settings - Bluetooth - Search, on the Android, iPhone, Windows phone whatever.
With camera, speaker, headphones or whatever the Bluetooth device is, you have to press a button on that device to send out the signal. On my Bowers and Wilkins T6 Speakers, there is a button on the top with the Bluetooth symbol on it. This is the part people usually don't do and ask for advice, thinking it will do this automatically.
When the Android device recognises it, click Pair, and if it asks for a code, the Default is '0000', (four zeros, no quotes).
Posted by ADMIN... on Nov 19, 2016
How do I pair my bc-au-bs-206-bk speaker to my phone
Tip & How-To about Miscellaneous
When the Android or iPhone device recognises it, click Pair, and if it asks for a code, the Default is '0000', (four zeros, no quotes).
This manual is probably close enough for this fine Chinese device.
https://fccid.io/2ASLD-P17/User-Manual/User-Manual-4196764
VIDEO
https://www.google.com/search?q=bc-au-bs-206-bk+speaker+pairing
JBL charge 4 stuck in demoo mode. How do I fix this. Also it can't turn on . when charging the power buttons turns on white and dosen't flash oor does anything.
Try doing default factory settings.
Step 1. Press the "Power" button located on the top center part of your JBL Charge 4 Bluetooth speaker. The speaker will be powered on when the LED backlight under the Power button is lit.
Step 2. Hold down the "Bluetooth" and "Volume Up" buttons at the same time for roughly three seconds. The Volume Up button looks like a plus sign. Additionally, it's important to hold down the "Bluetooth" button in the center of the device next to the Power button, as it's easier to hold down. After three seconds, the LED ring around the Power and Bluetooth buttons will briefly light up before the JBL Charge 4 powers down.
Step 3. Press the "Power" button again to turn the JBL Charge 4 Bluetooth speaker back on. The Charge 4 will instantly turn on in Discovery mode, with the Bluetooth LED blinking on and off, and the speaker making a pinging sound. This confirms that you've successfully reset your JBL Charge 4 to its default factory settings. You'll need to pair or re-pair any devices you want to play audio through the JBL Charge 4 speakers with the device.
How do I pair a Victsing Bluetooth speaker to my cell phone?
Hi
Try this.
Hold Down Power: Many Bluetooth speakers switch into pairing mode by turning the speaker off, then turning the device on while keeping your finger depressed on the power button. To notify you the speaker is in pairing mode, it will typically emit a sound or its light indicator will begin flashing rapidly.
Hold Down Pairing Button: Some Bluetooth speakers have a dedicated button for placing your device into pairing mode. Seek out a button on your device with the Bluetooth symbol next to it, then hold it until you hear your speaker emit a sound or its light indicator begins flashing rapidly.
your Bluetooth speaker now discoverable, it can be paired to your iPhone or Android phone.
Quick Pairing Instructions
  1. Open Settings.
  2. Open Wireless and Network.
  3. Open Bluetooth® Settings.
  4. Turn Bluetooth® on if it is off.
  5. Touch Search for Devices.
  6. Touch and hold - UGO.
  7. Touch Connect.
Mar 24, 2017 • Cell Phones
1helpful
Adjust volume on bluetooth mini speaker PSNANO PS-38
Quoted from the instruction manual:
"+/>>'" In TF/Bluetooth mode when short press this button: next song; long press: Volume up. Don't work in AUX mode.
"'<<\-" In TF/Bluetooth mode when short press this button: previous song; long press: Volume down. Don't work in AUX mode.
">''" In TF mode, short press this button: Play/Pause; In Bluetooth mode, short press this button: Play/Pause/Answer/End/Cancel dial/Pair. In Bluetooth mode, double click: Last number redial; long press for 2 seconds: reject calls. In TF/AUX mode, press it will be TF card and AUX exchange.
1helpful
Have bought a Braven wireless speaker (bluetooth) for my QT 5500. It sounds great when plugged into laptop but can't seem to get bluetooth to work. Will I have to buy a dongle
All depends, Does your QT 5500 have bluetooth Adapter? Bluetooth Software? I looked at the specs, I don't see Bluetooth listed, but doesn't mean you don't have it. In Device Manager, is Bluetooth Listed?
17helpful
I have a Centrios Bluetooth. I cant find the manual. I can't remember how to put it in pairing mode so I can add my Blackberry. Can you help?
Jan 18, 2011 • GPS
8helpful
I have a centrios bluetooth car visor speaker... and I cent remember how to get it in pairing mode so I can sync it with my new blackberry.
Sep 15, 2010 • GPS
93helpful
2answers
I need the pairing key for a supertooth voice model n15417
I had the same problem but after hours on the phone to Supertooth found out you need to reset the device:
From off, press the Volume + button.
2- While you press the Volume + button, press the MFB (green button) for one second to switch on the kit. You can hear a special ringing via the kit. The kit says the Bluetooth and PIC versions. The Bluetooth indicator is blinking blue.
All pairings and phone books of the SUPERTOOTH VOICE are erased.
You have to do a new pairing with your phone.
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
