SOURCE: Pass Thru, Analog Signal Converter How-To
I wonder if this is a MacroVision problem. Try this; take a VCR tape that you have recorded from the tv, try to record a commercial and then play this tape through your setup, I bet you it works. (Now take what I say next in the sense that it is given and that is as advice)When you are trying to push signal that you get from an analog source from the VCR by law that signal has to be encoded with macrovision to ensure that the signal can not be copied. Now the funny thing is you can transfer tapes which have not been encoded this is normal, what you need is a piece of equipment that removes Macrovision, here is a link that might help: http://www.regioncodefreedvd.com/copyeliminator.html also look up the company SIMA
SOURCE: video transfer from sony handycam ccd-trv 308 hi8 to a computer
I have a sony handycam ccd-trv 308 hi8 analog camcorder and I was trying to transfer videos from it to my computer. However, when I plug the S-video cable to the handycam and my computer, nothing happens. Does my computer require a driver to recognize the handycam because I cannot find any in the sites of sony for my handycam's model. Or am I using the wrong wire?
SOURCE: Get video off Sony Handycam DCR-TRV118 Hi8 to PC or Mac
You can use a Digital8 Camcorder to directly play 8mm and Hi8 analog tapes and output them to your computer via firewire Capturing 8mm/Hi8 with a Digital8 Camcorder
SOURCE: How do I transfer 8mm & Hi8 tapes to DVD using my computer?
just go to this link:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV740&SelectOS=7
download the usb driver for your camcorder. install. Set power switch to Camera or VCR. Select USB Stream to ON in the menu settings. then connect camcorder to pc.
