Question about Shop Vac Vacuums
Need filter for shop vac craftman 29044, 45 litres
Posted by robert murray on
Steve Pack
  • Shop Vac Master
  • 4,340 Answers
Check amazon, ears parts
Posted on Sep 10, 2018
5 Related Answers
Anonymous
SOURCE: shop vac
Vacuum is less than a year old and died in the middle of a use. No power... tried to plug it into 3 known, good outlets. Suggestions?
Posted on Jul 06, 2008
Anonymous
  • 10 Answers
SOURCE: DEWALT DW795 Vac filters
IT looks like the part number is 429704-56 and the Dewalt site shows list price being $51.68. You should be able to order that filter at a DeWalt dealer in your area, hopefully for a discount.
Otherwise, there is here online:
http://www.ereplacementparts.com/search_result.php?osCsid=2c10ce07c62a161bca9f80f981bf690f
Posted on Feb 26, 2009
Anonymous
  • 120 Answers
SOURCE: using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Posted on Sep 16, 2009
pappapumpdaf
Bob Sloan
  • 635 Answers
SOURCE: genie 400PC 16 gal shop vac but can't find filters
If you need paper filters, you can easily use a bag filter cut in half, and have less dust clouds than the original filter. Remember to use the lock ring. Generic ShopVac mini's have the same filter in foam.
Posted on Mar 11, 2010
Testimonial: "I have a lot of upright vac bags from long gone vacs & I hadn't thought about cutting one down! Good idea, now I've just got to go get a foam filter."
Where do Ifind replacement filter for my wet dry shop vac
tons of sellers on Amazon with good prices. just make sure you get one for "wet" if you plan to vac liquids.
Feb 21, 2015 | Shop Vac Vacuums
My craftmans shop vac sounds like it winding out and theres very little suction -the tub is clean what can i do to fix this ?
Most of the time this is caused by a dirty air filter unit that is blocked up, look there first.
Dec 21, 2012 | Vacuums
I have a 6 gall wet dry shop vac bye rigid . do i need a foam wet filter on the inside or will it work properly without the filter on i need it for water only. people in the store said the paper filter was...
Always use the foam filter when using the Shop Vac, keep your filters clean and it will operate more smoothly. When sucking water I usually take the foam filter off as well as the cylinder filter
Oct 02, 2017 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
New vac no instuction manual . i need to vaccumn
No you do not need the filter to pick up glass. If you are vacuuming up dust/dirt then use the filter.
Jan 22, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Sep 22, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
Using shop vac 52722-90 for wet applications
Sep 16, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Cannot find a filter
In a pinch a discarded flannel pajama sleeve can be employed as a filter on your shop-vac. grab up an end and twist it together and fasten with a piece of wire. the open part slips over the cage of the vacuum and fastens with a large flat rubber band. I'll try to find a source for a filter for you and will get back to you.
Oct 01, 2007 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Vacuums Logo
64 people viewed this question
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Bill Johnson
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
