I tried resetting the remote and even unplugged the player and replugged it. Same result. HELP!
SOURCE: Plays CDs but not DVDs
Melisha, I had a similiar problem. Go into the onscreen menu with the remote using the "ACTION" button on the bottom left of the remote. Using the arrow keys in the center of the remote, move to the menu for the audio processing. It will have menu items for DTS, Dolby Digital etc. Change the menu parameters for the "Down conversion" to "yes", get out of the menu mode and see if your DVD works again. If not, make sure there is no DVD or CD in the player, and press the "open/close", "pause" and the double left pointing arrow buttons all at the same time for about 5 seconds until the display on the DVD player says "INITIALIZE". This resets your machine. I hope this helps you.
SOURCE: buttons don't work, wont eject disk
the model you have pictured does not have a dvd,only a monitor
SOURCE: DVD player reads open and the when I push the play button it reads invalid key
I am having the same issue with Toshiba SD-P1850
SOURCE: Hi, how do I turn
Some DVDs can't change the Audio or Subtitles in Button of the Remote, try change in the Menu,
Try again with the Remote with another DVD Disc...
Bruno Gamba
SOURCE: The player gives a "cannot play" message for all types of media
Unit probably has a defective disk motor that is in border line failure. When problem again arises, have the motor replaced
