Question about KitchenAid Dishwashers
KitchenAid dishwasher KUDM25SHBL1, can't get soak&scrub to start. Grandson pushing buttons
Posted by Greg mcgrath on
ray gallant
    Top Expert:
  • KitchenAid Master
  • 69,148 Answers
Smack grandson's hands
Posted on Aug 16, 2020
5 Related Answers
Anonymous
SOURCE: Bosch Dishwasher stuck in "Scrub Cycle"
The Control module on our SHU43 blew this morning and when I took it apart to get the module out, I discovered why two of the Cycle selections no longer worked..... the little plastic lever that pushed the switch behind the fascia button - had broken off. You may have the same issue. It's not a cheap fix though as a new module is gonna cost me $175.
Posted on Mar 28, 2008
dragonsthatk
Albert Getty
  • 547 Answers
SOURCE: Kitchenaide builtin - take 20-30 pushes on start button
change the controls you can get at loocal appliance shop take model number when you go
Posted on Feb 17, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: I have a kitchenaid KUDS01FLss2
Hi.
The appliance is in lock mode.
Try first disconnecting power by tripping circuit breaker or disconnecting power cord for two minutes.
After that the appliance may still be locked, at that point you will need to reset the dishwasher control module.
The control module is reset by pressing a key combination of keys.
Combination is:
  1. HI-Temp Wash
  2. Heated Dr
  3. Hi-Temp Wash
  4. Heated Dry
  5. Hi-Temp Wash
  6. Heated Dry
This model does not have heated dry, and the combination uses Energy Saver button instead:
  1. HI-Temp Wash
  2. Energy Saver Dry
  3. Hi-Temp Wash
  4. Energy Saver Dry
  5. Hi-Temp Wash
  6. Energy Saver Dry
Press the button in rapid sequence without big pauses, or it will not work (it is often called button dance).
Regards.
Ginko.
Posted on Nov 16, 2010
mddog26
  • 77 Answers
SOURCE: kitchenAid kudpo1flss dishwashe wont do
If the unit won't start and there are no signs of power make sure you're dishwasher is getting power. If so then likely you will need a new fuse which if you go to the link below, you can download a video to show you how to replace the fuse on your dishwasher.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/control-repair-whirlpoolkitchenaidkenmoremaytagjenn-air-amana-dishwashers/
Good luck
Posted on Mar 01, 2011
Will Rodriguez
  • 5 Answers
SOURCE: Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Posted on Sep 12, 2012
Kitchenaid D/W will not start, lights not all working, getting power. What's my problem?
Sylvia.....is the clean light flashing or any other for that matter? Either way it sounds like the control board is locked up. There are many posts on here about how to reset it. Try the following: With the door open:
Push Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry (all the lights should light up) then close the door and hit cancel. Push the buttons as fast as you can - within 4 seconds. This will unlock the control board and you should be able to restart the dishwasher. There are many issues with this Kitchenaid including the door popping open during cycle issue. I have dealt with all of them over the past 8 years of ownership. Finally replaced it with a used Miele and sold the KA on craigslist with full disclosure of all the issues and it's history. I even threw in the rubber door stopper that we resorted to using to keep the door closed. Let us know if the above procedure works for you. Good Luck.
Nov 30, 2014 | KitchenAid 24 in. KUDS01FLSS Built-In...
How do you reset a KitchenAid dishwasher model: KUDE70FXSS4?
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there.
Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
Jan 02, 2013 | KitchenAid Dishwashers
I have a kitchen-aid dishwasher model # KUDio1ibl6 and it will not come on and the clean light flashes 7 times then pauses and blinks 7 time again. Do you have any Idea what this code stands for I do not...
Hello Asa,
The light blinking seven times is a error code specifically it's error #7 .The E-7 error indicates the part called the flow meter is bad. To clear that error code and get the dishwasher to start push within 3 seconds
HIGH TEMP WASH -HEATED DRY-HIGH TEMP WASH- HEATED DRY
then push CANCEL sereval times to dishwasher shuts off..it should start and run then
If the blinks 7 times again the flowmeter will need to be replaced
ON some models the "HIGH TEMP WASH" button is labled power scrub instead of high temp wash
so in that case push POWER SCRUB-HEATED DRY-POWER SCRUB-HEATED DRY then cancel as described above
In case the E-7 error returns and the flowmeter needs to be replaced the part number for it is W10195536
Gene
Aug 24, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
I can't turn on my KitchenAid Superba dishwasher. I pushed Normal and Start, and the Normal light started flashing, but didn't turn on. Pushed Cancel and now both the Normal and Cancel are...
Did you try turning off the power and then connecting it again?
If still problem is there open the door. Press the following sequence of buttons HI Temp Scrub, Energy Saver Dry,HI Temp Scrub, Energy Saver Dry. Now close the dishwasher door and latch it too and press the cancel button. This must reset the dishwasher.
Aug 13, 2011 | KitchenAid 24 in. KUDU02FR Built-in...
Model # KUDM25SHBL1 Child lock is on and can't remember what button(s) to use to turn it off
Press and hold the 'Energy Saver Dry' button for 4 seconds to either turn on or off the child lock
Apr 25, 2010 | KitchenAid Dishwashers
Clean light is blinking
Open the door, push high temp scrub, push heat dry, push high temp scrub again and push heat dry again, then close the door, your welcome
Apr 04, 2009 | KitchenAid Dishwashers
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Open the dishwasher door, press in rapid sequence the following keys: Hi Temp Scrub, Energy Saver Dry, High Temp Scrub, Energy Saver Dry. Close the door until it latches and press the Cancel key. The machine should reset itself. It worked for me when I had the same problem
Oct 20, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Setting cycles and turning dishwasher on
Frenda Most likely the problem with your dish washer is shorted one or more pads on the key panel. To fix it the key panel has to be replaced. If you'll provide the complete model number and color for the control panel for your dish washer, I can help you to find the best deal on this part. Gendos
Jan 17, 2007 | KitchenAid 24 in. KUDG25SH Built-in...
Dishwashers Logo
109 people viewed this question
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
