Question about Radio Communications
SOURCE: .wmv animation
.3gp is the best file format for all handheld devices,especially for nokia n series mobile phones.
Posted on Jun 11, 2008
SOURCE: does not give steam.
Actually there was no category for clothes steamer, and before entering information I was prompted to pick a category so I chose vacuums hoping that when my problem was diagnosed it would be understood that the problem is a clothes steamer that has stopped giving off steam. Please help if you can. I appreciated your time.
Posted on May 20, 2009
SOURCE: hand held pro 83 scanner
http://support.radioshack.com/manuals/ome20-501.pdf
Posted on May 31, 2009
SOURCE: hand held casio tv vs digital signal
I have my handheld Casio TV-980 up and running with a
converter box. All I needed (in addition to the converter box and standard
rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a
1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The
1/8" plug on the adapter goes in the external antenna jack on the TV, and
the other end connects to the coaxial cable that goes to the TV (RF out) jack
on the converter box. The adapter would have been a little cheaper at my local,
independent electronics store, but they were sold out.
If your antenna has flat 300 ohm wire connections, you'll
need a balun (Radio Shack catalog # 15-1297, about $8) to connect it to the
coaxial cable that goes to the Antenna (RF in) jack on the converter box.
I’ve tried 2 different converter boxes with the handheld
TV, and they both work well: Insignia (Best Buy’s house brand, same as Zenith)
and RCA (from Target, same as Venturer), so any government coupon-eligible
converter box should work.
A few other tips:
1. I always turn on the converter box before I turn on
the TV. The cpnverter box seems to take control better that way.
2. When I turn on the TV, the tuner doesn’t automatically
go to channel 3 or 4 (where it should be set when using a converter box), and
the picture quality is poor. If I use the tuner on the TV to get to channel 3
or 4, the picture quality is vastly improved. I have to do that every time I
turn on the TV.
3. Placement of the antenna is very important. I like to
watch my handheld TV when I'm on the computer, and the reception is better the
further away from the computer the antenna is located. I'm actually using a 6'
coaxial cable for the antenna, but I could also have used 2 shorter cables with
a coupler that has an F jack at both ends (Radio Shack catalog # 278-304, about
$3).
If your battery-operated TV does not have an external
antenna jack, instructions for connecting it to a converter box can be found at
http://www.digitaltvtrainer.com/national/showme-battery-tv-converter
There are a few battery-operated converter boxes
available, but for do-it-yourselfers, this web page also contains instructions
for building a 12-volt converter box power supply.
Posted on Jun 20, 2009
SOURCE: My hand held car unlock
you need to re-program the remote for your vehicle.. your owners manual will tell you how to program it... hope this helps
Posted on Dec 10, 2010
