Microwave Ovens Logo
Question about In Microwave Ovens
How do you change the fuse in microwave?
Posted by Beverly Garwood on
1helpful
Fridigaire Microwave blows fuse after several weeks of use
I would change the interlock switch under the door catch. They do intermittant things like this when contaminated.
3answers
Microwave portion malfunction
Did you mean that the microwave oven won't turn on at all?Did you try replacing the fuse?
1helpful
Does this unit itself have fuses inside it? If so, how do I access them.
Shelia, A lot of microwaves do have internal fuses, Links below will show how to change them.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix Microwave Oven Simple Fuse Replacement
Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
Microwave Line Fuse Replacement Whirlpool Microwave Repair Part W10422951
How to change a fuse in frigidaire microwave?
Good Morning Friend,
I understand you want to know how to change a fuse in your Frigidaire microwave. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to change out the fuse with ease. Hope this is helpful.
-Best Regards-
WP
Is there a fuse in a frigadaire microwave
Good Afternoon Friend,
I understand that you want to know if there is a fuse in your Frigidaire microwave, model# FGMV174K. Looks like there are 2 different fuses inside your microwave. Neither are fuses like in your home's circuit breaker. There is the magnetron fuse, which controls the heating, and the monitor switch with ceramic fuse. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your microwave status has changed successfully. Hope this is helpful.
-Best Regards-
WP
I have a built-in AEG Microwave code MC166(0E?) My son unfortunately used the microwave as a timer so it was on for 30mins without anything in it. It now won't turn "on"; no light/clock...
What fuse did you change? The fuse on the wiring that leads to the microwave needs to be intact, then the fuse in the Microwave itself needs to be checked. Usually there is a plug where the microwave is plugged in, in the cabinet above the microwave, you can take another small appliance or a power tester to make sure power is available in the outlet where the microwave is plugged in. If the power is on at the outlet then you'll know that it is the microwave itself that has turned itself off for some reason. You can get manuals for these ovens at this website
1helpful
The house fuse that runs the circut the microwave is on blew when replaced the microwave did not come back on,is there a reset button or fuse on it.
There is a fuse inside the microwave oven but i don't recommend opening the oven and changing it. There are high voltages inside even when the oven is disconnected from the mains.
But if you are careful enough, you can change it. If it has a electronic control (With a digital display) maybe there is another fuse on the controller board, near the front panel.
Before even opening the oven, make sure it doesn't work on another power outlet.
And make sure you change it with the same type and rating of fuse!
Emerson Model MW8627W does not heat after changing fuse!
check the magnitron and capacitors one of this is bad
Top In Microwave Ovens Experts
vince
Marvin
Marvin
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
