Question about Sharp Televison & Video
1 yr old baby playing with the remote and now there is no audio/sound coming from the TV. what can we do? I tried menu and audio settings, but nothing worked so far. we don't have any audio equipment connected to it, just the regular tv speakers built-in the tv. thanks
  • lecaaragao Aug 03, 2009
    looking at my audio settings I have
    MTS : MONO or STEREO or SAP (it is on MONO)
    Equisound: ON or OFF (it is on OFF)
    Speakers: ON or OFF (it is ON)
    FAO: ON or OFF (it is OFF)
    Surround: OFF, SIMULATE or SRS (it is OFF)
    Audio Adjust
    Problem Solver:
  • 17 Answers
Try the SAP button (the one you push for spanish on second track). Sometimes there can be a position where no sound comes out so a person can use a surround system etc.
Posted on Aug 03, 2009
Black screen and no sound no menu no anything after remote hit
test with another remote.
buy a cheapy remote at dollar general
and see if you can connect it to the tv with code number
code numbers on internet
Jul 31, 2017 | DISH Network 322 DTV Receiver
I have dvd tv combi and the sound will not go above 30. I have tried going into settings and the volume but nothing happens.
follow this steps and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Oct 25, 2013 | Televison & Video
My techwood tv will not play sound and the colour is not right. how do I fix this?
see the charts troubleshooting and fix it. God bless you
No sound
  1. Disc is dirty or damaged. Clean the disc or try another disc.
  2. Reset the color system of the player or the TV set.
Try a direct connection from the DVD player to the TV set, instead of via other components.
Oct 14, 2013 | Gemini 1 Device Universal Television...
I have 32 inch proscan no sound
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Mar 30, 2012 | Televison & Video
Try to hook up ps3, great pic no sound on tv or receiver tv is 7 yr old rca 50 inch scenium. i have tried to hook this up 20 different ways , no sound. is there something in the tv menu that needs to be...
Tries the PS3 with another tv?Make sure is not the PS3.Tries go into the tv menu to do tv audio resetting,so it can go back to factory setting,see if that make the PS3 it responses.
Jan 23, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Mar 26, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Television does not turn on
please check the ac plug at the wall and also behind the tv. most newer tv's have a cord like a computer that plugs in the back and they sometimes come loose. are the rest of your electronic components working ? if the ac cord is plugged in, your power supply inside the tv has gone bad. you cannot blame your 2 year old if this power supply has gone bad, this was "NOT" caused by playing with the remote control.
Jan 18, 2009 | Televison & Video
Hooked up to sony bravia 52" tv and can barely hear sound
You'll want to turn of the TV speakers in the Remote Menu and try turning up the volume level of the TV, which usually controls the level of the RCA outputs, as well
Feb 02, 2018 | Yamaha RX-V596 Receiver
8-9 yr old Mitsubishi tv
Good Day,
Go into the 'menu' then advance area to the audio and turn speakers on. You must have TV's orig remote. Or go to menu:
OPTION MENU "MENU 1370" SERVICE MENU "MENU 2357". Choose reset.
Good Luck, big IRISH.
Aug 21, 2008 | Mitsubishi Televison & Video
Had a universal remote for my symphonic wf2703 tv my daughter tryed to change something with the remote now plays the dvd player ok turn it off all that comes up is a black screen with video on it the...
I had to clean the sensor area for the remote on the tv somehow got something on it. I wonder how, my little 4 yr old daughter had know idea how it got there lol.
Aug 01, 2008 | Televison & Video
Televison & Video Logo
113 people viewed this question
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
