The EF error usually means that there is a problem with the evaporator fan circuit. This could be a wiring problem, an issue with the fan or with the circuit boards.
First, check if there has been ice build up blocking the fan. If ice built up, the fan motor may fail and need to be replaced. When ice builds up, you may also have a refrigerant leak. Any problem with the compressor/refrigerant has to be dealt with by a professional. Check for continuity in the wiring harness between the fan and the control board. The control board may need to be replaced if there is no problem with the fan or the wiring.
The parts for the FGUS2642LFO are available here: https://www.appliancepartspros.com/search.aspx?model=fgus2642lfo .
I hope this helps.
SOURCE: error code er ff on my kenmore elite bottomfreezer model 795.7756
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
SOURCE: EF error code on frigidaire
My Frigidaire also got the dreaded E-F error code and stopped cooling. Technician over the phone told me to unplug it for 5 minutes and then plug it back in to see if the control board would reset itself. Did that with no luck. Unplugged the refrigerator last night while I tranferred my food to a spare fridge in the garage. Plugged the fridge back in this morning (9hrs later) and it works fine with no error codes. It looks like the control board has reset itself but how long it takes...I dont know. 10.. maybe 15 minutes? Well more than 5 at least. Guy over the phone told me that you can buy DRY ICE at a local grocery store and put it some in your freezer and a little bit in the frigdge to keep the food cold for a day. I had a spare fridge but I thought that was a good tip for anyone that needs to buy time for a tech to come repair the fridge. I had just bought $300 in groceries the night before so that tip would have come in handy if I did not have the spare fridge. I have no idea what the EF error was for but it's been 5 hours since I plugged my fridge back in and it's running fine so I'll cross my fingers. Got around to cleaning the fridge and plugging in a surge protector too. Hope this post helps someone out there.
SOURCE: Frigidaire model ftr18b freezer works, fridge is only cool
Info relating specifically to the Frigidaire FRT18B5ABB:
1.Refrigerator unplugged remove the bottom back panel. (Access cover with label. The rectangular shaped panel on the back, at the bottom) Place the screws in a container.
Also remove the Kickplate Grille in the front, and the defrost pan.
2.Use the wand tip on your vacuum cleaner, and vacuum this area out. Pay special attention to the condenser coils, and the fan. Use care as you don't want to bend the fan blades. After you have vacuumed up as much as possible, see if your vacuum has where you can attach the hose to blow air through it. An air compressor, hose, and air nozzle would be REAL handy right now! Blow the condenser coils, and all areas clean of any gunk. (Hair, spider webs, etc.) If this is not feasible for you, you'll need some sort of long, thin, dust 'bunny', and have to dislodge this 'gunk' physically. Then vacuum.
3.BE SURE to replace the bottom back panel, (Access Cover)! It is a VERY necessary item! If your fridge doesn't have one at present, make a temporary one of cardboard, and tape it on. This access cover is needed.
If your refrigerator side is only cool, and your freezer is cold, you may have a problem with the Cold Control, (Temperature Control), or the Defrost Timer. (Timer-Defrost)
http://disruptit.com/manualgateway.cfm?pdfwanting=34242&username=anon&AV=123345&I=99.169.118.45
SOURCE: Frigidaire FRT045GM freezer works but fridge does not
hi ,
your freezer cabinet need to get all out and open the back wall.
Thank u so much!??
You're welcome. I hope you can determine the exact problem quickly. Cindy Wells
