Question about Samsung Audio Players & Recorders
Owners manual for Samsung YP-Z5 - Samsung Audio Players & Recorders
Posted by Robert W Boos on
Terry
  • Samsung Master
  • 11,377 Answers
5 Related Answers
Anonymous
SOURCE: My YP-Z5 unresponsive
There is a reset button at bottom by the usb connection port, try pressing that i had similer problem downloaded the manual from samsung site which said try doing that so i did and now it seems to work fine
Posted on Nov 22, 2007
Anonymous
SOURCE: Connection to my computer
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Doodles1
Posted on Jan 07, 2008
Anonymous
SOURCE: touch pad will not work
did u get some water on it too like me?
Posted on Feb 04, 2008
Anonymous
SOURCE: How do you reformat samsung YP-Z5 mp3 player?
Go into my computer then right click on the removable storage icon and then on format.
Hope this helps, I have had mine for nearly 2 years and it has only allowed me to play one album for the last 18 months, the worst £130 I have ever spent.
Posted on Mar 15, 2008
DerMullerMan
SOURCE: SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Posted on Jun 07, 2008
I need a replacement usb cable to connect my samsung YP-Z5 MP3 player to my computer
You can purchase a replacement USB cable for Samsung YP-Z5 MP3 Player from amazon >>LINK
Oct 23, 2011 | Samsung YP-Z5 MP3 Player
Samsung YP-Z5
Vista = not compatible with this player
Apr 18, 2008 | Samsung YP-K3 MP3 Player
Doodles1
Dec 31, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Nov 18, 2007 | Samsung YP-Z5 MP3 Player
Other way to sync the yp-z5 withought windows media player
Here is the user manual for your player if you need it; http://downloadcenter.samsung.com/content/UM/200601/20060124115711375_YPZ5-USA-ENGLISH-0.0.pdf Page 18 states that you can only sync with wmp 10, there is no alternative software that will do the job. Hope this helps :)
Apr 18, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
126 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
