1992 Oldsmobile Cutlass Supreme Logo
Posted on Aug 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Outside temperature display (next to a/c display?)
I'm pretty sure when I got the car that the outside temperature displayed next to the a/c temperature... But it doesn't/doesn't anymore. Any ideas?
Thanks!
  • seurhja Sep 12, 2009
    Thanks, I will look into this!
Sean Wright
Level 3:
  • Oldsmobile Master 2,045 Answers
  • Posted on Sep 11, 2009
Sean Wright
Oldsmobile Master
Level 3:
Answers
2045
Questions
Helped
626750
Points
6368
The ambient air temperature sensor at the fron of the car has gone bad, a new one can be obtained from any GM dealer.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
1helpful
How do I change my 2008 Cadillac back to celsius
Push and hold the Ambient (outside) Temperature button down while pressing the Temperature Down button. After several seconds the display will toggle.
2answers
My Buick Rendezvous has the DIC. It works fine but the temperature is always 0 celcius (says 0C). Got 2 new outside air sensors from junkyard and no change. Should i check something else like voltage?
It should be possible to test the sensors with an ohmmeter (I think) as they will likely be temperature sensitive resistors or thermistors.
Testing the voltage was the thing to do in the old days of analogue and direct current systems but I think you will find the electronics on your car is digitally based and difficult or impossible to test with an ordinary meter. An oscilloscope will probably be needed...
Outsite temperature next to clock light turning orange
check near front bumper for a tiny black sensor somewhere near number plate the sensor seems loose or bad connection on wire ,not 100% sure where sensor sits but pretty sure its a bad connection on plug to sensor as it is a common prob on bmw when sensor loose /bad connection show minus 40deg when its hot outside and display plays up vw polos have same prob
1helpful
Outside temperature sensor
The outside air temperature indicator's displayed temperature can be recalibrated. Press and hold the reset select button for 10 seconds . While you continue to hold the button, the display will scroll through temperature settings from +3 to -3. When the desired correction value appears on the display, release the button, and the recalibrated outside air temperature will be displayed. Each time a desired correction value is entered, it replaces the previous value. Give that a try mmkayyy:)
Outside temperature display is widely inaccurate.
Change heater output temperature sensor.That is a SAAB dealer job.
4helpful
Climate Control Outside temperature display incorrect
you need to replace the ambient temperature sensor or do the math
1helpful
Climate control display for Outside temperature
Had the same problem, replaced the ambient air temp sensor in front of the radiator. Cost is like 10-15 bucks. Don't worry if temp doesn't change right away. Took me about 5 miles and then it worked great.
3helpful
1999 VW Beetle outside temp display not working
For general awareness, the outside air temperature sensor is located above the inside mirror.
Try to reset the temperature measurement unit: 1. Switch engine on. 2. Press and hold clock minute (min) and hour (h) buttons simultaneoutly longer than 3 seconds. The display will show new temperature measurement unit.
1helpful
Outside temperature
The exterior temperature display is built into the Automatic temperature control unit. or the A/C controls. Look at the buttons for the A/C unit and press the one that is marked "EXT". This will display the outside temperature.
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you an Oldsmobile Expert? Answer questions, earn points and help others
