Hey,
i was bathing my daughter and had my 6233 in my pocket not thinking. and she managed to kick it out of my pocket and into her baby bath, at times it turns on and works for a few days but now its just going white and saying nokia on the main start up screen... help zara x
One of two these would cause this, either something is under the plug and not allowing it to drop down all the way or the rubber seal is worn and needs to be replaced. Either way you need to remove the plug and check for anything that would prevent it from dropping , if nothing is found replace the seal or plug.
The right answer is to remove the drain trap and clean it out.....if this trap is not accessible then you have a major carpentry issue to gain access. You can also try several gallons of boiling hot water to soften the crayons up.
The only thing you can do is dry it out more with heat(hairdryer). Remove the battery while doing this. If you still have the same problem then yes, unfortunately the keypad has shorted out.
Feed: Supplies List->Care->Dry Food/ Dog food can ( your choice)
Water: supplies List-Care- Water or Milk
Bath: Supplies list- Care- Long hair/shorthair shampoo
* If you have none of these items then:
Go Out->Shopping->Pet Supply
Or for discount items go for a walk and choose the route to the discount store.
I think believe it or not that there is moisture still in the phone. I dropped my 6300 in the bath and managed to get the battery out of it quickly enough and dried it out thoroughly and it works as before. The best thing to do is to take the battery out of it and leave it on a radiator on low heat face upwards for a few days. Then try it without the memory card first the re-insert the card and see if it registers. Hope this helps.
A basic equation is : Water + Phone = Dead Phone
Warm water and a phone is really bad news, the level of corrosion inside the phone after a warm bath is significant.
You could try to disassemble the phone and clean it on the inside, but you should not get your hopes up.
In many cases, repairing the phone (after water damage) is much more expensive than getting a brand new one.
