SOURCE: how to reformat my nokia 6280
go to menu at your mobile screen >select settings > now select "Restore Factory Settings"............that's it you can do in nokia 6280
SOURCE: LG Vu Cellular phone memory card does not read.
I had same problem-you must push memory card ALL the way in until it clicks!! Also, make sure connection under settings is set to "mass storage"
SOURCE: G1 16gb micro sdhc card not read on my pc
Umm..... did u try formating the card? before you do that backk all info on computer via usb cable. if the G1 says mount to usb go ahead and mount it. in your case it might not work. but try it anyway. if no good goto settings on the G1 then goto SD and internal memory and tap eject SD card then pull it out then push it back into the slot tell me if it works on the PC now.
SOURCE: i did a reformat but still my phone cannot detect the memory card
1. If your memory card can be detected on your computer, then try to completely format the card.
2. Goto Start >> My Computer >> Right-Click the memory card icon >> Format >> Uncheck the Quick Format option >>
Start >> OK / Yes (confirm the request!).
3. If the memory card cannot be detected / readed by your PC, phone, or camera, then that card has become corrupt / unrepairable!
4. You should replace that memory card with a compatible one!
please rate this advice if it helps...tc! :)
SOURCE: 3110 Cellular Phone: memory card not formatted, operation failed...
This is a problem due to the memory card IC.The IC has to be replaced .Better contact service centre.If you are familiar with Mobile Circuits you can follow the instruction in the following diagarm.this will solve the problem
