Electrical Supplies Logo
William Boyle Posted on Sep 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does anyone know from experience if a Eastern Steel 1000 generator has a bonded or floating neutral ?
Larry Blais
Level 3:
  • Master 800 Answers
  • Posted on Sep 09, 2018
Larry Blais
Master
Level 3:
Answers
800
Questions
0
Helped
330382
Points
2735
Hi. Neutral is bonded on this model. Look at the end cap of the generating case (opposite end from pull cord). You will see at the top left curve. An Earth Ground symbol with a green wire attached next to it. Curious why you want to know but I hope this helps.
5 Related Answers
Anonymous
  • 154 Answers
  • Posted on Jun 14, 2009
SOURCE: i need to get an outlit for my 1000 watt genorater
tyr ebay
Anonymous
  • 3600 Answers
  • Posted on Nov 30, 2009
SOURCE: should the earth / neutral output of a kubota new
You only need to bond it to earth if you are working near water it should have a GFI fault breaker on it, if there is no earth showing check the plug and see if the wire has broken inside the duplex box and if the earth wire has broken off the duplex receptacle. My suggestion is to bond it to a 6 foot grounding rod if in use on the ground and a wet area. And of course following local laws and NEC rules and regulations.
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Apr 13, 2012
SOURCE: Hayward Electronic chlorine generator bond to Jacuzzi magnum 1000
when i done mine i cut the pipe and glued another connector in to the pipe that goes to the jets ,
Your Consultant
  • 825 Answers
  • Posted on Dec 09, 2014
SOURCE: my friend has a eastern steel generator 2years old an has not been started I have done every thing I could think of any ideas thanks John
if it has sat for 2 yrs with gas in it, it will need to be cleaned.
varnish builds up and blocks jets and filters
Eugene Rounds
  • 1169 Answers
  • Posted on Dec 14, 2014
SOURCE: were can i buy parts for my 1000 watt eastern steel generator?
Generator Guru Try this link, no parts breakdown but may they what you looking anyway.
The 220 plug has 4 leads and my 220 compressur has 3 wires how do i make the conection
The four wire 220 twist lock receptacle Two hot wires, one neutral, and a safety ground. Depending on your generators setup the neutral and ground are bonded as one; unless, it setup for a floating neutral.
You would normally connect the two hots and neutral. and leave the ground open on the four prong twist lock plug. Just make sure the compressor is earth grounded on its end.
1helpful
I need to know exactly what wire to disconnect on my wh6000s portable generator to float the neutral so i can hook up to home panel with interlock switch. I will ne using the 30 amp 25 ft. cord into a
You need to have the wiring diagram for the generator but they didn't include one in the owners manual and nothing is shown the IPLs that I found.
DISCLAIMER NOTE: The following should be done only by knowledgeable service personal trained in area of servicing these portable generators. The information is what service personal needs to know in order to unbond the neutral and chassis ground. If done incorrectly you will put yourself and others in danger of electrocution.
To determine if your generator uses a floating or bonded neutral perform this simple test. With the engine off, use an ohm meter between the chassis ground and neutral conductors in the outlet. If it indicates open circuit, the neutral is floating. A short circuit will indicate neutral bonded to ground. I don't recommend doing this to household circuits due to the possibility of exposed AC and damage to the meter.
The jumper from ground to neutral, likely on one or both the 120VAC duplex outlets that needs to be removed. Connect ground connections on both outlets to the chassis ground and ground the generator chassis and frame to earth ground.
Were can i buy parts for my 1000 watt eastern steel generator?
Dec 14, 2014 • Garden
How do I disconnect neutral bond on a dewalt generator
Please be careful, you need a neutral bond for the GFI outlets to work when you are using the generator as a mobile unit and grounding the generator with a ground rod or building. When you are merging with a building with a grounded system, simply remove the two neutral wires (White) at the generators internal terminals from the generator frame but keep them connected together and terminate connection.
Bonding on a generator questions
Q. If I was to keep the tie between ground and neutral in the generator during standby use, would I have to break the neutral tie coming into home from grid?
A. Never disconnect the neutral line as it enters your house. It is held very well at ground potential. Each transformer is grounded, and every home supplies ground as well. The neutral coming in is the reference to both live lines, and without it, anything connected to either live line could see up to 240VAC depending on what is across the other side. Install a proper transfer panel, and the neutral issue will be taken care of.
Q. Where would I ground the generator at this time in this situation?
A. The generator will be grounded through the extension cord plugging into the transfer panel. Your home should have one ground connection only, adding a ground rod at the generator could create other unwanted safety issues.
Q. At this time is it safe to run an extension cord off generator direct to power a drill for example?
A. Yes. The transfer panel will take care of any neutral and ground bonding issues, provided things are wired correctly.
Q. If I was to lift the neutral to ground in generator and tag generator as floating neutral, then would I leave neutral unbroken in service panel?
A. Yes. The common point for neutral and ground will be provided in the main electrical panel.
Q. Could I use the 15 amp outlets on generator safely in this position to run a drill outside? I see generators with floating neutral have a 15 amp duplex outlet on cabinet also. In this situation would I install a ground at the generator?
A. If you were connected to the house with the four conductor extension cord nothing else will be needed.
Q. If you have a floating neutral generator and use it in a stand alone mode, nothing to do with a home, do you place a ground rod down? What happens with the neutral and ground connections? What about a generator on a truck or trailer?
A. In stand alone use, you should connect to a ground rod. Neutral and ground should also be bonded in the generator. The easiest way to take care of this is with a dummy plug inserted into one of the duplex outlets or the twistlock outlet. Jumper ground and neutral in the plug. A generator on a truck or trailer will follow the same rules for neutral and ground bonding, ground rods, etc.
Q. If the generator is a grounded neutral type and you only run the two live lines to the house in an illegal back feed situation where main disconnect is off but neutral still connected will I have 120 volts available in house between each hot leg and the utility grid system neutral? Would someone get shocked if standing next to generator at that time and touched it creating a path from ground to the generator?
A. The only time I would consider backfeeding a house is if the main lines were torn down and laying on the ground. I did this once after Hurricane Juan caused a tree to tear the lines off a neighbors house. The lines were still connected at the pole and were live once commercial power was restored, but there was no possibility of the generator backfeeding to the street. It took almost two weeks before the power company could get them reconnected. We still turned off the main breaker and installed a padlock to prevent it from being turned back on. The house was totally isolated from the grid so I felt it safe to connect in this manner. The generator connected via a 20 amp two pole breaker in the main panel, and there was power available for everything in the house - well pump, electric stove, all lights, etc. Generator neutral was floating as described above. Power supply was limited, they were careful not to overload and trip the generator breaker.
Q. At the same time I went to a friends home and after killing the main breaker and all 240 breakers ran a 3 wire cord from the generator 240 volt outlet direct to his pump, now isolated from the house panel using both 120 volt lines and ground. I then ran a 12 gauge 20 amp extension cord from the generator duplex outlet to a double male pig tail and back fed a kitchen outlet so he could have lights in the house. 1/2 the house to be exact. This was also a grounded neutral generator but we didn't have a problem. I did however drive a ground rod at the generator.
A. I think you were lucky this time. Electricity can be potentially dangerous and can kill and burn if not used correctly. Double male plugs should never be used as invariably there is exposed 120V on one end. If you miswire one end you can send 120V onto the neutral. At best this will trip a circuit breaker, but not knowing what else is done, could easily create a lethal voltage on the chassis of certain equipment. It gets back to doing something properly or not doing it at all. Why run the risk of personal injury or death?
1helpful
Is it possible to change a ef4500ise from a bonded neutral to a floating neutral
Unless you are going to use this exclusevly for 240V service, this is a bad idea. Your 120V legs will float between 0V and 220V.
1helpful
2answers
Is the nuetral on my tg7000 bonded or unbonded? The panal that I AM INSTALLING ASKS THIS QUESTION.The answer is not in the manual or on the generater. THANX, ROD
The question regarding whether the Neutral is Bonded or Unbonded refers to the connection between the Neutral and Earth output terminals on the generator. The question relates to the correct operation of (Earth Leakage) Safety Switches.
The easiest way to check this is to use a multimeter to measure between the Neutral and Earth contacts in the generator output socket. Bonded should give a reading of less than half an Ohm. Unbonded will be open circuit.
1helpful
In need of a muffler for a 2800 watt easter steel generator, anyone know where to get one
I have parts for 2800 and 3300 Eastern Steel Generators including a Muffler you
Top Eastern Steel Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Eastern Steel Electrical Supply Expert? Answer questions, earn points and help others
