Question about Water Water Heaters
Have a giant model 55000151-1 gas water heater. Does not heat enough water only runs warm 2 to 3 minutes
Posted by Terry kelly on
ray gallant
    Top Expert:
  • Water Master
  • 68,617 Answers
BAD THERMO-COUPLE
Posted on May 23, 2020
5 Related Answers
Anonymous
  • 68 Answers
SOURCE: poloma gas demand heater only getting warm water not hot 10y old.
move the dial up and get back to me
Posted on Jan 20, 2009
gary1121
gary miller
  • 332 Answers
SOURCE: hot water is cutting out after 2 - 3 minutes whilst showering
check the screen on the cold water intake on the cold side,, you might have to flush the system out, and do you have the shower head water restricter in, if not you may be using to much hot water,,, how many other hot water fixtures are running at the same time? try running just the shower,,,if this is a tank water heater the dip tube could be bad that is on the cold side it takes the cold water to the bottom of the tank and forces the hot water out,, if you ar only getting a couple of min of hot water and the dip tube is bad it is not going to the bottom but just at the top and not getting all the hot water you will need a plumber
Posted on Jun 06, 2009
Anonymous
  • 248 Answers
SOURCE: Heating unit comes on, but doesn't get water hot enough
OVERHEAT STAT OR FAN
Posted on Nov 13, 2009
Anonymous
  • 6 Answers
SOURCE: Not heating water hot enough or as much water.
You probably have a bad heating element. Probably the upper element.
Posted on Feb 03, 2010
motor1258
Mike Butler
  • 6674 Answers
SOURCE: atwood rv water heater model G6A-8E heats water to
Normal causes for that would be by-pass valve not in proper position, or defective, allowing cold to mix with hot, or thermostat not touching up against tank properly, or defective. Do you know where that thermostat is?
Look where the black foam cover is, with white letters, below pressure relief valve. One is lettered ECO, other THERM. If you note where the wires go, so as not to mix them up , and pull them off, then peel back the foam cover, you'll see 2 little round discs, that are held against the tank by a small spring. They need to be checked that they are in there properly and are up against the aluminum tank.
Posted on Apr 25, 2010
Rennai hot water heater very slow to heat up!
I would check the gas pressure at the burner. It should be 3.5 inches water column on the manifold. Hope this helps.
Sep 09, 2014 | Water Heaters
What can i do to get my water heater heating the water hot enough for a hot shower, water is just warm these days?. Any suggestion?
There's an, "Aquastat " on the water heater, turn it up one increment and see if that helps. The water heater should turn on in under a minute if it's functioning properly.
Jul 07, 2014 | Stiebel Eltron Water Heaters
Hot water varies
I do not know how old this unit is or what model but many water heaters are not sophisticated enough to measure the temperature, but heat based on water flow and temperature rise. To start, tankless water heaters turn off every time you turn the hot water off. Lets use an example. You use the facilities, wash your hands then turned off the water and take a shower. You will bring the already heated water (from washing your hands) from the pipe up to the shower. Then the cold water that comes into the pipe from the reactivation of the water heater comes up the hot water pipe with warm then hot water just behind.
If this is not your problem, keep reading. Every unit I have been called to see were installed wrong. Check your installation manual to see if the problem with the system started with the contractor.
First, check the temperature of the water from the heater. If it is too hot and you are mixing too much cold water in, the unit will turn off because there is not enough water flow to keep it running.
Second, turn off the valve at the water heater and turn on the hot water at a faucet. If the water does not stop running, there is a "plumbing cross over" usually caused by a failing pressure balance valve in a shower.
Third, if the unit has not been serviced, go to bosch-climate.us to find a tankless water heating professional in your area. Totally Tankless LLC
Mar 14, 2014 | Bosch & Tankless LP Hot Water Heater
Why will my water heater not kick back on after the hot water used up??
Troubleshoot by type of gas control valve
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
More information is needed, for example brand and model number, type (tank tankless solar assisted indirect commercial residential new-old) etc that appear on label located side of tank
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 27, 2013 | Little Giant Water Heaters
How do I troubleshoot a 6kw 240 volt circulation heater. This heater is on a baptistry; they fill it up before service starts and use it 90 to 120 minutes later and water is still cold.
It is very possible that you just are not giving it near enough time...
I have worked on them before and they do not heat the water very fast....
you will need to give it at least 12-24 hours to heat the baptistry properly...
That heater will only heat about 30-35 gal./hour....on a 50F rise in water temp. ....figure how many gallons you have there and then do the math...
heatman101
Apr 13, 2011 | Little Giant Water Heaters
HEATER WARMS UP AND THEN GOES OUT.THEN IT HAS TO BE RELIT TWO OR THREE TIMES A DAY
Relighting the pilot of any water heater is a pain. The first thing to do is call the water heaters manufacturer for information on your specific make and model. If your water heater is under warranty, they will provide technical advice and free parts.
1. Replace the water heater's thermocouple. Make sure the pilot flame is centered on the shiny end of the thermocouple; it requires a certain amount of heat to produce enough electricity to open the main gas control valve.
2. Replace the main gas valve control.
3. Replace the water heater; I know this not what anyone wants hear.
Aug 26, 2010 | American Standard Water Heaters
Pacific water heater light dims and water does not heat up
sounds like an electrical problem, consult an electrician
Jul 12, 2010 | Pacific International Water Heater...
The temperature indicator changes as soon as I begin to take a shower. How can you help me.
try unplugging the controller to see if it's a glitch in the contoller. If not you probably do not have enough gas running to it so it can't heat the water fast enough due to lack of gas
Oct 03, 2009 | Rheem Tankless Hot Water Heater...
Heat loss
Sounds like a thermostat problem.
Apr 10, 2009 | Water Heaters
Water Heaters Logo
169 people viewed this question
Top Water Heaters Experts
Don Walper
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Water Heater Expert? Answer questions, earn points and help others
