Question about Whirlpool Home
What is the size of the tub of the whirlpool 907675
Posted by Sally Darrow on
My whirlpool high energy washing machine style master #907675 just stopped working in the middle of the wash cycle. What can I do to get it to start working again?
not a good model # check on face of opening inside door frame.
door lock switch maybe your problem depending on model#
washer should show error code on electronic display by lights flashing or led read out if not lighting up can be control board check your home power first
Jul 03, 2016 | Whirlpool Washing Machines
Replace air hoses on whirlpool?
What size of air hoses? What do they go to?
Is this an Air tub?
US Parts Center
Mar 06, 2014 | Maax 101054-004 Topaz Whirlpool Bath Tub -...
Hey I'm an expert on this! You have a bad Drain Pump. It happens very frequently because of the amount of work it does. Replace it and your machine will return to Glory!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 16, 2014 | Washing Machines
No problem as yet. Just purchased a whirlpool front load top of the line. The instructions are very good except I can't find any instructions regarding adjusting the water level for smaller and la
For the Whirlpool WFW96HEAC front-load washer, the water level adjustment is made by the washer based on the size of the load. If only 3-4 items are in the tub, it will do a small load. If you fill the tub completely, it will do a large load. (Note: if the clothes are packed into the tub, they can't tumble and won't get cleaned.) Loading the tub with clothes until it is 1/2 or 3/4 full are the other load sizes.
Please add a comment with the model of your washer, I'll be glad to give additional help. I hope this helps.
Mar 01, 2013 | Whirlpool Washing Machines
We have a stylemaster #907675 Heavy duty. It will not spin anymore, can you help diagnose?
It is a computer problem and you can get it fixed free, due to a recall by Whirlpool. Call the company and complain. My daughter had the same problem.
Jul 16, 2011 | Whirlpool Washing Machines
Water is trinkling down the bello and filling drum after wash is complete
Theres an electric water valve. You have to find out if its the hot or cold thats leaking and replace it.
Jan 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
TIA
RJ
Jan 08, 2010 | Washing Machines
I have an older Whirlpool washing machine (Stylemaster # 907675.) It leaves behind lint galore and white smudges that are almost impossible to clean off. Do you think it has a filter that might need...
WHIRLPOO STOP USING FILTER IT MAY BE COMING FROM THE TUB. TRY RUNFIN A WASER CLEANER LIKE C.L.R. CAUSIM LIME AND RUST REMOVER. AND TAKE THE SOFTER OUT BY PULING THE BLUE RIND UP AND PULL THE SOFERNER UP AND PUT IN WASHER TO GET CLEAN IN HOT WAER LOW CYCLE.
Jan 25, 2009 | Washing Machines
Home Logo
66 people viewed this question
Top Whirlpool Home Experts
john h
Mike
Andrew Taylor
Andrew Taylor
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
