Hi.
Disconnect the power supply. Using a cocktail stick, paper clip or similar, gently insert it into the Restore hole located in the AV port. It may take a few attempts to get the correct location of the button, you will feel a button click when located, keep it held down.
With the button held down, Insert the power cable and wait until the recovery menu has appeared. You can now release the restore button. Please read the Recovery Menu section below for how to proceed.
Good luck.
SOURCE: How do you reboot the Denon AVR-2807 to factory settings
To reboot, turn receiver off by the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory. Enjoy this info is straight from Denon's Tech support. I had to do this on mine
SOURCE: need to restore acer to factory settings
contact acer you can get there number from the website and they will let you purchase a restore disc for 15bucks
If you have the recovery CD, then put that in the drive, reboot the laptop and make sure you boot to the CD. The recovery process will start up and you can restore the laptop to it's factory settings. Make sure you have all of your documents, music, etc. backed up.
SOURCE: reboot to factory settings without disc
Can you still log in to Windows Vista?
e machine has a RECOVERY MANAGEMENT allows you to restore sytem to factory default or reboot and tap F10 and follow instructions.
Good Luck!
SOURCE: want to set computer back to factory settings or out of box state
Restart the system hold down F11 function key till it beeps then follow procedure.
Rate this fixya!
