Question about The Office Equipment & Supplies
My Ott floor lamp fell to the floor, and does not work. I replaced the bulb, but still nothing!
  • 3 Answers
Hey!
I recommend a lamp from Brightech, they have a 5-year warranty on all of their lamps - www.brightech.com
I really liked this one - https://brightech.com/products/sky
Posted on Feb 13, 2020
  • 1,032 Answers
I saw where some of the ott bulbs look like other bulbs but will not work. Are you sure you purchased the exact same bulb.(If you have one which does not interchange.
https://www.youtube.com/watch?v=ZvAt0IaL8YY
Are you sure you have the correct bulb.
https://www.youtube.com/watch?v=2TiNY7wdGZ8
OttLite Customer Service Tips - 18W Floor Lamp
https://www.youtube.com/watch?v=rhmdFOEAnqw
Lamp Not Working - Lamp Repair
https://www.youtube.com/watch?v=kHzyplcmIM8
Posted on Sep 06, 2018
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 20 Answers
Odd problem with ceiling fan and LED
This is a common issue with LED bulbs in the application that you have it installed in, When you changed the socket it reset the unit. Most of those wont ever see an LED because the LED wont draw enough current. Then control box depends on a current draw in order to stay on. LEED bulbs don't have enough current draw.
Oct 12, 2017 | Dryers
My brand new ott lite will not turn off. what am I doing wrong
Get in touch with Ott Lite at: http://www.ottlite.com/t-customerservice.aspx
May 08, 2015 | Ott lite Ottlite 759803 Task Lamp Blue
Why does my Ott light flicker but not come on completely?
check and replace bulb first, if not that then most likely a ballast problem, which sends a boost of the correct amount of power to ignite the bulb then lessens the flow of power it needs to stay lit.
Sep 06, 2014 | Ott Light OttLite Truecolor Table Lamp
Is it the ballast or the bulb which is faulty?
Put a new bulb in, if it works, the bulb was a problem, if it still flickers, the ballast is a problem.
Apr 10, 2014 | Ott Light OttLite Truecolor Table Lamp
The bulb is flickering. I have replaced it but the new one also flickers
replace the ballast I can send you one cheaper than you could purchase it I have 100s of them in storage always a ballast if they flicker
Apr 10, 2013 | Verilux Modern Deluxe Natural Spectrum...
The on/off switch seems to be broken
If you haven't used it in a while or if it is in a cold area, it may be a warmup issue, try turning it on a waiting a few seconds, even in the best time there is a delay. You are correct to expect the bulb to last a long time most Ott bulbs do last!
Dec 06, 2012 | Ott Light OttLite Truecolor Table Lamp
Removal of burnt out bulb in ott lite
Depending on lamp the bulb is approximately a 1/8 turn with a slight push toward the base to release the bulb, If you have not purchased the replacement bulb take the old one with you, some "high end" lamp stores will have replacements, if not the website will help. Good Luck!
Douglas
Sep 12, 2010 | Ott Light OttLite Truecolor Table Lamp
Replaced bulb now shows only triangle with exclamation mark. no picture and nothing else works
Check your lamp door. If it looks good, remove it. Now, push the lamp door up. Reach around the TV with the remote and try to turn it on. If it comes on, your lamp door wasn't on right. If it doesn't, you may have something going on below the lamp. It the lamp exploded, the hot glass fell out of the lamp and went down into the cooling fan below. It may be stopping it from turning. I hope this helps, best wishes.
Apr 29, 2010 | Samsung HLP5085W 50" Rear Projection...
190 people viewed this question
Top The Office Equipment & Supplies Experts
Thomas F. Schneider
Keith Love
James Cagle
James Cagle
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
