Turn radio on or turn ignition on - radio will show a number of lines on screen. enter code with numbers pad one code number at a time until next flashing bar opens and wait 10-20 seconds. If failed start procedure from scratch.
That whole deals sounds fishy. Brake job should be about $100 depending on parts. That part about needing to replace axle to replace ball joints doesn't sound right. I've been a diesel mechanic for 30 yrs and bought, drove and fixed used cars a bunch. Not that specific one, but plenty of them. Get another opinion.
All vehicles sold in the USA in the past 30 yrs use a 195 degree thermostat. It opens at that temp. Electric cooling fans come on around 220 degrees to prevent the coolant from boiling.
You need to find out what the error code is - Service engine soon means an error code was generated.
With the problem you discribed, it sounds like a coil problem. If a crack has developed in the casing, the crack size changes with temperature changes. Also make sure that the wires are in good shape.
You need to drain all old fuel out of the fuel tank, the fill with fresh fuel, clean or change filters (air and fuel) and if possible blow fuel lines through with compressed air. Check the plugs are clean and gapped correctly, check the engine oil is ok. Then use some easy start in the air filter to get it to fire up, after 10 yrs it will be difficult to start, but should be alright after a few runs. I hope this helps
