Question about Logitech Office Equipment & Supplies
The Logitech K350 keyboard uses on-screen Caps and Num Lock indicators no longer reliable.
These messages should appear for approximately 2 seconds each time either key is pressed. Recently I have to regularly reset the keyboard to 'default settings' for it to be reliable. What's causing this?
Posted by Wendy Forsyth on
Tom Chichester
    Top Expert:
  • Logitech Master
  • 55,375 Answers
The keyboard is failing.
Posted on Sep 06, 2018
Testimonial: "Is that likely when it's absolutely fine in every other regard?"
5 Related Answers
Anonymous
  • 505 Answers
SOURCE: laptop keyboard is not working correctly
Accoring to the problem you have mentioned i am sure the keys are not connected properly. The tab key is connected on the Caps lock key. Moreover make sure you press the fn key to check for any changes as it is the key which helps you toggle in Laptop
Posted on Oct 08, 2008
mumma_1
Debs
  • 903 Answers
SOURCE: Logitech keyboard default settings
is there a key on the keyboard that says F mode? if there is press this to set it to F mode and then it will stay that way until you press it again
Posted on Oct 25, 2008
Anonymous
  • 5 Answers
SOURCE: My Logitech EX110 wireless keyboard has no light indicator
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Posted on Jun 30, 2009
graysand
wilfred graham
  • 558 Answers
SOURCE: caps lock notification driver for logitech ex 100
No, there is none .Is it visible when its on?Or do you have to turn it on.You might want to look at the keyboard properties in control panel,see if you can customize it there.
Good luck
Posted on Sep 14, 2009
rolando ingking
  • 832 Answers
SOURCE: Keyboard does not type but wireless mouse keeps on working
You have a busted keyboard, buy anew one.
Posted on Sep 21, 2009
CAPS LOCK STATUS DOES NOT APPEAR ON THE SCREEN OR ON KEY BOARD
I don't know how to make this status appear, however here's a way around it.
Go to Control Panel. Ease of Access Center > Make the keyboard easier to use. Check the box next to "Turn on Toggle Keys. Hear a tone when you press CAPS LOCK, NUM LOCK, or SCROLL LOCK".
From now on, you're going to hear a beep whenever you press CAPS LOCK key on or off, the beep is slightly different depending on whether you press it on or off. Slightly higher pitch when you press the CAPS LOCK to stay on.
Oct 08, 2014 | Logitech Computers & Internet
Logitech Wave K350 won't boot with num lock on
Have you changed or updated anything else on your system? Added any other Bluetooth devices? I have the same KB, always boots with Num lock on. It worked with both Vista 64 and now Win 7. Maybe the driver and the specific USB port combination is not working. Try plugging the BT antenna into another USB port.
Mar 04, 2014 | Logitech Computers & Internet
MK300 Logitech Keyboard I do not know when CAPS are on or off. Have changed batteries there are no lights to indicate on off
MK300 does not indicate if caps lock is on or off with lights. It will show a message on your screen for 2 seconds when you press it. You will need logitech setpoint on your computer for it to work tho so here is the download link http://www.logitech.com/en-us/584/3131
Jun 22, 2011 | Computers & Internet
Do any of the current Logitech Keyboards have an led on the numlock key??
Not on their wireless products (uses battery power), but you can download this handy litttle app that shows the CAPS,NUM,and SCROLL LOCK status on the screen. It also gives audible feedback when typing in all caps and when the status is changed.
http://download.cnet.com/NumCapsScroll-Indicator/3000-2072_4-10604212.html
Jan 12, 2011 | Logitech 967437-0403 Keyboard
I recenty purchased a Logitech keyboard and find it diffult to describe my disappointment. Since I had a stroke I only have the use of my left hand and have to watch the the keyboard rather than the...
Unfortunately, by design this model indicates the status of "caps lock" and "num lock" on the computer screen. I do not see a work-around for your problem. A huge majority of keyboards have a "caps lock" indicator on board. Perhaps you need one of these?
Nov 26, 2009 | Logitech Cordless Desktop EX110...
How can you know when you are in upper or lower case
I have a feeling there are two ways to tell. First, the receiver unit that connects to your computer should have two LED light on them. One will have an "A". This will be lit when the Caps Lock is on. The second LED has a "1" over it, and that's your Num Lock indicator.
The second way will be after you install Logitech's software, text will appear across bottom of your screen (usually in green) for a second or two telling you if you just pressed the Caps Lock or Num Lock buttons.
Aug 25, 2009 | Logitech Cordless EX 100 Mouse
Logitech Setpoint Caps Lock indicator won't work
Hi, I suggest you to update to the last version of set point version 6.00 Yes logitech is listening that's why they released 3 set point version since the 4.72 that you are running. www.logitech.com/download Thanks and have a nice day ! J-
Aug 01, 2009 | Logitech Cordless Desktop EX110
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Cap Lock on or off
Feb 11, 2009 | Logitech Cordless Desktop EX110
Is there no indicator to inform you when the caps lock is on
The LED's for caps lock, num lock, and scroll lock are located on the base/ reciever unit. Logitech did this to make your keyboard batteries last longer.
Dec 17, 2008 | Logitech Cordless Desktop MX 3000...
1,837 people viewed this question
Top Logitech Office Equipment & Supplies Experts
Christopher Stearns
Ekse
Are you a Logitech Office Equipment and Supply Expert? Answer questions, earn points and help others
