Question about Water Water Heaters
Water in electrical section mp345b - Water Water Heaters
    Master:
  • 791 Answers
* Water in any part of the electrical is a hazard to equipment and operators.
* Shut down all equipment to this device.
* Shut down all equipment if the area is flooded.
* Call your hot water vendor for service.
* Call your Gas utility if this is a gas heater.
*** Following is for information only.***
* Water leaks are from external pipe connections or direct tank connections (that may be under fiber insulation wrap.)
* Shut down electrical before servicing equipment.
* Check if breaker tripped out (half way position). Note which breaker is tripped then shut down breaker to cut power to heater control.
* Shut off gas supply if this heater is gas heated.
* Isolate this heater if your using back up or secondary heaters.
* check electrical box and dry out (after isolating and repairing leak.)
* Use a fan to help dry out area.
* Check components for water damage. Burns, Electrical damage. Replace components as needed.
* Pull out components to dry them if still damp.
* Note that due to time constraints, you may need to replace complete control unit and use the wet one as a back up once it's dried out.(say a week in a dry room).
* The Gas Service techs are pretty good at trouble shooting gas fired equipment. Follow their recommendations.
* Note; equipment failures of this type is usually an indication that the whole system needs service. Heater systems are usually set in place and runs with minimal maintenance. Management usually forgets about this till something happens (a leak?) then it's time to do a complete system overhaul. Many just replace the heater (usually after 8-10 years for a gas heater. 3-5 years if it's critical to operation)
Aloha, ukeboy57
Posted on Sep 06, 2018
6ya staff
SOURCE:
Relighting sunmaster 26 solar hot water service after gas being turned off to house
see if pilot light unit or electric ignitor if no pilot area on gas valve then ignitor if pilot section relite
Apr 22, 2018 | Water Water Heaters
Bosch AE125 no hot water, blinking light
Hey Andy. Do you have your owners manual? There should be a section near the back that will break down the diagnostic code the flashing light is giving you. If not remove the front cover and look inside should be a wiring diagram and light legend.
Dec 14, 2013 | Bosch PowerStar AE125 AE125 Whole House...
Unit stiebel Tempra 24Hot water is running through house but cold water pipe is getting hot. Hot water pipe is not getting hot. When cold water connection is removed and water is turned on hot water is...
follow this steps and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating elements and replace if faulty (see below).
If there is not enough hot water, adjust the thermostat settings. As needed, reset, test and replace thermostats and heating elements if faulty.
If the water is too hot, adjust the thermostat settings and reset. Test and replace the thermostat or high-limit cutoff (see below).
An electric water heater is a 240-volt appliance that can deliver a fatal shock. Always turn off power to the heater at the electrical panel 585dc480-4881-44a8-afda-7267c0f3de26.jpgbefore beginning work, and verify that power has been shut off. Make sure others in the house know not to restore electricity prematurely. If you have any doubt as to whether electricity has been turned off, seek professional assistance.
Oct 02, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
Little to no flow through unit
Check for crossover:
http://waterheatertimer.org/Crossover.html
Clean water filter located just above where water enters unit.
Copy following link for Bosch powerstar manuals with brief troubleshoot section in each;
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html#manual
Call service technician who is qualified to work on computer that heats water. For plumbing problems, call local plumber. These are two different things.
Fix any brand tankless yourself, same day, by replacing the whole thing. Buy electric water heater at Lowes for $285 and be up and running by sundown.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 05, 2013 | Bosch PowerStar AE9.5 Electric Tankless...
How to light water heater 660
Instructions for lighting Reliance 660 are located on the side of water heater just above the gas control valve.
If you are having other problems, read your product manual, or go to reliance for copy of manual, and read troubleshoot section:
http://www.reliancewaterheaters.com/lit/om.html
Unfortunately Rheem-Reliance does not post service manuals for their product. However other companies do post service manuals that might be similar to your water heater
Copy following link for troubleshoot service manual by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Jul 29, 2012 | RELIANCE ELECTRIC WATER HEATER
LOWER ELEMENT IS NOT GETTING ANY VOLTAGE ON MODEL 65220RS
Short answer: Thermostats may be bad. Replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Long answer:
1) If water heater has some hot water, then upper element is good and water heater has 240Volts, and best suspect is burned out lower element.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
2) If water heater has no hot water because 240volt circuit breaker is tripped on one leg, and only 120Volts is arriving at water heater, then upper part of water heater can appear to have voltage and lower part of water heater can appear to have no voltage.
Open following links for troubleshoot steps:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Add a comment for more help
Jun 14, 2011 | RELIANCE ELECTRIC WATER HEATER
Got storage heating and hot water tank .lights on cotroller to heat water but not heating water
1) You report that your tank-type electric water heater has lights on the controller.
Please look at label on side of tank to get brand and type of water heater.
Add a comment with all information you have, including description of product.
This will let expert possibly find a manual, and read manual alongside you to assist as you fix water heater yourself.
Keep in mind that expert cannot see your water heater, and that many things cause water heaters to malfunction, and that troubleshoot section of product manual is good place to start.
2) Search manufacturer's website for product manual so you can fix water heater yourself.
http://waterheatertimer.org/Water-heater-manufacturers.html
3) If you have electric water heater and don't want to add a comment with identifying information, then look at following page for do-it-yourself troubleshooting:
4) If you have energy smart water heater, you can access information and manual at following link, and possibly fix water heater yourself:
Product manual link shows on page, and gives phone number.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
5) If you do not have tools or know-how to fix water heater yourself, then call a plumber.
Plumbers are expert at fixing water heaters.
6) Post question of professional water heater forum, to double check anything a plumber, friend, or fixya expert says:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
7) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 14, 2011 | Element 2000W 8" WATER HEATER ELEMENT
Water heater does not produce as much hot water as it use to. Could it be, that one of the heating coils is out. If so is ther a reset switch? Before I have someone check the coils.
Ordinary tank-type electric water heaters are fully repairable by homeowner.
A) Rheem electric water heater website:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Find age of Rheem: look 3rd and 4th digit of serial number, for example 06 is 2006
B) Water heater has some hot water.
That says certain things: upper element is working, water heater electricity is working, reset button is not tripped, and heater is not experiencing run-away overheating event.
http://waterheatertimer.org/How-it-works.html
C) That leaves 4 suspects.
1) TP valve is running hot water out of tank, or leaking faucet is running hot water out of tank.
Check for leaks
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) Lower element is burned out.
Test lower element using inexpensive multi-meter from Home Depot.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace element with same wattage shown on label, and clean out sediment:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) Upper or lower thermostat is bad.
Replace both thermostats for about $25.
3) Burned or shorted wire located between upper and lower sections of tank.
Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially check lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
Feb 11, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 49 gal model 81V400B - hot water lasting only 5-10 minutes then takes an hour to heat back up.
A) Basic info on Rheem
Find age of Rheem: look 2nd and 3rd digit of serial number, for example 06 is 2006
C) That leaves 4 suspects that cause lower amount of hot water.
1) TP valve is running hot water out of tank -or- leaking faucet is running hot water out of tank.
Check for leaks
Feb 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
100 people viewed this question
Top Water Heaters Experts
Don Walper
Level 1 Expert
auntyjack
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
