Filters are clean, passage from shoe to sump is clean, and rotors work okay when I switch out upper and lower. So, other tests I can to to figure out if it's the flap valve, where do I get one, and (gulp) how to replace?
SOURCE: fisher paykel - dishwasher - 2 drawer dd603i - top of dishwasher loose
The dishwasher while running began to beep constantly and then BOTH drawers began to beep with blue lights and read F1 with the small picture of a wrench. It will not turn off but keeps beeping with flashing lights.
SOURCE: Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
SOURCE: fisher & paykel 2 drawer unit
yes there is. It is just inside the white hoses that drain the system. 1 per drawer. They cost about $0.50 but are a real pain to get to. This flap will go bad in about 3-5 years and maybe sooner depending on the temp of the water used.
If the bottom flap goes bad, using the top drawer will drain into the bottom drawer.
SOURCE: Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
