Question about Zanussi Dishwashers
How do I access the internals of a Zanussi dishwasher ZSF6126 700018000002 132850 please?
    Top Expert:
  • Zanussi Master
  • 85,223 Answers
Pull it out of the cabinet and they are all there.
Posted on Sep 05, 2018
Zanussi Dishwasher DA6152 Blowing Main Fuse
A guess is that the water has leaked into the motor, and the machine is shorting out.
As a retired firefighter, may I please recommend you do not try to start it again?
It could start a fire.
It is probably time to buy another dishwasher.
Be blessed.
Mar 27, 2013 | Zanussi Dishwashers
I have a zanussi izzi and it works ok for about a minute and then it stops working and the programme light starts flashing continuosly?? any ideas?? water comes in fine and wash pump works for about a...
Hi
The issue can either be with the unit not draining properly or the timer/electronic board itself has gone bad & should be replaced. First clean the drain hose and the drain pump for any clogs, you can do this by taking off the bottom access panel. After cleaning if still the issue is not resolved then the timer/control board has gone bad and needs to be replaced. Hope this helps...please post back for further assistance.
Daniel
Jan 12, 2011 | Zanussi 24 in. IZZI ALU Built-In...
Hi do you have an instruction manual for the zanussi zdf511 dishwasher please
You can get the manual on the link below. Click on where it says it is free.
http://safemanuals.com/user-guide-instructions-owner-manual/ZANUSSI/ZDF511-_E
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 26, 2010 | Dishwashers
Dishwasher not getting hot or drying
Same Problem Here - I Noticed your Post is quite old - Please did you solve the problem my friend..........???
[email protected]
Apr 29, 2009 | Zanussi 24 in. DE6844ALU Free-standing...
Zanussi ls9
write to me if you need the manual.as for the soap the dishwasher uses only liquid professional soap and you must connect it inside the tank . there is also a blue pipe for the rinse aid detergent
let me know if you need anything else
Mar 21, 2008 | Zanussi 29 in. LS14 Free-standing...
Zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Nov 26, 2007 | Zanussi ZT485 Built-in Dishwasher
Dishwashers Logo
57 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Renee Knafel-Bullock
ray gallant
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
