Hi Tiffany,
The Numlock on your laptop is on that is why instead of letters you are getting numbers. In order to get it back to letters please check the key that says Num Lock where the green light is lit up all you have to do is to press it again to disable Num Lock. If in case you can't see it you may want to try pressing Fn + F11 once and check if you are still getting numbers, press Fn + F11 to disable it. Hope it helps.
It may be that you have NumLock on - these function represents a KeyPad on the Letter Keys - usually the U,I,O,P,[,J,K,L,;,M kEYS are replaced with numbers - to switch on/off you should have a key with Number Lock on it possibly abbreviated to NumLck or NumLK etc - activate that Key - may need to use in combination with the FN key as well to toggle the Number Lock on and off - also often a light appears to show its ON
HI, If you Are writing numbers instead of letters when you press the
keyboard of your laptop and you must hold down the Function key (Fn) to
write normally.
This is due to the fact that the digital lock is activated. To solve
this, simply press the Fn+Numlk or depending of the model, press the
button or Fn + Shift +Numlk
When the RH side of the keboard types numbers instead of letters then the Num Lock (number lock) key has been pressed. Press the Num Lock Key again to return to letters again, usually this is usually done by pressing the Fn key plus and probably the Scroll keys, this key will be also marked NumLk, and there will be a LED light that will indicate when the number lock is on.
Number lock, a situation where numbers instead of letters are typed is as a result of the digital lock being active. to deactivate pressing the Fn+Numlk or Fn + Shift +Numlk keycombinatioins
You need to press the NUM Lock key.
The NUM lock key is usually the same key as the ScrLk key but to select the NUM lock you need to press and hold down the Shift key and then press the NumLk/ScrLk key. A LED light will light up to indicate the number keypad is on.
