Question about La Crosse Measuring Tools & Sensors
Outdoor sensor is flashing red on La Crosse W86111 atomic clock. Batteries are less than 3 months old. What could be causing issue? Sensor is on wood fence away from elements. Indoor readings good.
Posted by Kathy Murphy on
4 Related Answers
Anonymous
  • 3 Answers
SOURCE: 3M Precision Digital Atomic Wall
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Posted on Jan 15, 2009
Andrew Tunnera
  • 30 Answers
SOURCE: skyscan atomic clock weather
Make sure the battery contcts are clean of any corrosion.
-AAT
Posted on Feb 22, 2011
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I need a manual for
This site lists several including some desk models on two pages and each has unique downloadable instructions. You'll probably find a close match.
http://www.klockit.com/depts/AtomicClocks/dept-52.html
Posted on Mar 16, 2011
Ron Reynolds
  • 433 Answers
SOURCE: Replacement Outdoor Temperature Sensor for Atomic Clock
Search the manufacturers website and ebay. It may require a little time and effort.
Posted on Jan 02, 2018
A manual for La crosse atomic clock Model # w86111
You can find the manual for the LaCrosse W86111 on the product page: https://www.lacrossetechnology.com/w86111 . Click on the Support tab. The current link to the Manual is https://www.lacrossetechnology.com/media/catalog/product/w/8/w86111_english_033016.pdf . A Quick Start Guide is also available.
I hope this helps.
May 31, 2018 | Home
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
La Crosse Model W86111, Setting
an atomic clock ........ no user manual ?
1 Digital Atomic Wall Clock Model: W86111 ' Quick Setup Guide
pdfstream.manualsonline.com/0/0a0678fd-f9df-4e8f-8c98-0b4794c5453c.pdf
User-Manual
content.etilize.com/User-Manual/1031159306.pd
Oct 19, 2016 | Home
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
Batteries for clock
They could have been a bad batch of batteries. Sometimes batteries aren't fully charged as they should. Try another batch. If the same thing happens go back to the store and request either a replacement or a refund since the clock should have a 2 year warranty
May 19, 2014 | La Crosse Technology W86111 - Wall Clocks
La crosse support
Check the battery in the outside sensor. If the outdoor sensor is hard wired to the clock (or fresh batteries doesn't fix the issue) the unit needs to be replaced.
Jan 16, 2014 | Home
My remote sensor Tx14TH-LCD-B started flashing several days ago and I have gone thru the factory reset new batteries and decided to buy a new sensor then discovered they have been discontinued along with...
I assume you have tried removing the batteries at both ends, reinstalling batteries at the sensor end then the indoor end, waiting without touching anything until the outdoor temp registers and heaving a sigh of relief as things are back to normal. I also assume since the word atomic is in the header that you have an atomic clock function. If nothing works or doesn't work right you probably need to replace the system.
I have a much simpler LaCrosse system which, at this moment, is showing an outside temp of 56 degrees BUT the clock doesn't work and failed early on. I share your frustration.
Nov 04, 2013 | La Crosse Technology La Crosse S98642...
Lacrossetechnology
Hi Susuan,
One of these methods below should get your device working properly. Good luck!
LaCorosse Tech Support email address.
The product information page
From the manual:
915MHz RECEPTION CHECK FOR OUTDOOR TEMPERATURE SENSOR
The atomic clock will receive the temperature data within 3 minutes. If the temperature data is not being received 3 minutes after setting up (the display shows "- - -"), then please check the following points:
1. The distance of the atomic clock or outdoor temperature sensor should be at least 6 feet (2meters) away from any interfering sources such as computer monitors or TV sets.
2. Avoid placing the receiver onto or in the immediate proximity of metal window frames.
3. Using other electrical products such as headphones or speakers operating on the same signal frequency (915MHz) may prevent correct signal transmission and reception.
4. Neighbors using electrical devices operating on the 915MHz signal frequency can also cause interference.
Note:
When the 915 MHz signal is received correctly, do not re-open the battery cover of either the outdoor temperature sensor or atomic clock, as the batteries may spring free from the contacts and force a false reset. Should this happen accidentally then reset all units (see Setting up above) otherwise transmission problems may occur.
The maximum transmission range is 330 feet (100 meters) from the outdoor temperature sensor to the atomic clock (in open space). However, this depends on the surrounding environment and interference levels. If no reception is possible despite the observation of these factors, all system units have to be reset (see Setting up).
May 24, 2013 | La Crosse Technology Ws-8418u-it Atomic...
My outdoor sensor no longer transmits the temperature
Have you tried replacing the batteries with good ones and setting it up again?
Mar 07, 2011 | La Crosse Radio Controlled Atomic Clock
Measuring Tools & Sensors Logo
761 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
