Question about Jamo Audio Players & Recorders
Hi, I have a Jamo i300 sub.the left speaker contact doesn't work
In the back on the left contact speaker ,when i plug in the satellite speaker doesn't sound good, I already try the satellites speakers, the cables, and are working ok. So I think that the problem is in left plug in contact. Is there any way to fix it? thanks
Posted by Luis Leal on
5 Related Answers
Anonymous
SOURCE: JBL Creature doesn't work
make sure the triangles on the plugs are lined up when you push in the plugs!
Posted on Sep 01, 2008
Anonymous
SOURCE: Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Posted on May 09, 2009
Anonymous
  • 9 Answers
SOURCE: No sound from the System, Power light is on the
make sure you plug the subwoofer into the green jack port on your pc.
Posted on Oct 16, 2009
Grubhead
Grubhead
  • 5700 Answers
SOURCE: I have cambridge audio azur 640a amp. Problem I
The fault is on the amp! It sounds like the protection circuit is detecting a surge on the channel and shuts it down to protect the speaker. I would check the semiconductor device(s) for the right channel on the heatsink of the amp. You might even see damage of burning on one!
Posted on Jan 04, 2010
Anonymous
SOURCE: ADA745 speakers have no output
Had the same issue as treefarmer and guest. Initially I thought that the voltage controlled pre-amps were the problem as well but further testing proved that wrong. If you remove the yellow wire from the RT Front speaker PCB and measure the voltage at the wiper of the pot it is still too low (should swing from 0 to 5 volts). On investigation it turned out that the pot was failing.
I couldn't find a proper replacement pot so had to fix the broken one. After removal and dissassembly it discovered there was a leakage path between the carbon trace and the bushing assembly. The top deck which contains the carbon path for the wiper can be removed by bending back the tabs that hold it to the metal case. Carefully cleared the shorting path with a probe and retested with an ohm meter..
Re-installed and wala it works!
Posted on Nov 04, 2010
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
Sep 13, 2012 | Jamo SUB 200 Subwoofer
I think we had a power surge and my jamo i300 speakers have stopped working, how to open the subwoofer, i've tried undoing the 10 screws around the edge........
Perhaps some triage first before you open it up.
Are you sure it's just the speakers that are 'damaged'. The control dock is a vital link in this. Try other sources attached to IT. Or a source plugged into the Line Input directly on the back of the sub. Identify the correct patient before doing the surgery.
May 27, 2011 | Audio Players & Recorders
What batteries to put in the jamo i300 remote control
Remote Control Battery Replacement
To replace the battery, remove the two screws on back of the
remote and disassemble. It is a "Button" type battery not sure what the number is but look at the battery and find the number on it and replace it with the same style battery
To download a free owners manual go to this website
http://www.jamo.com/na-en/support/owners-manuals/
Jan 14, 2011 | Jamo I300 Docking Station
Please help! Jamo SUB 300 subwoofer still blows (0.8A) fuses after replacing a faulty thermistor, despite a high ohms reading directly across AC mains terminals on the board. What is causing the fuse to...
hi,
i have a jamo 250 sub.the blue light is working.when i connect the jack to the left line IN according to the manual it makes a sound as well.but seems not working.is it related to the fuse????i know the fuse box.but i dont know how to remove the fuse to check.pls help me out.my receiver is onkyo tx-sr 608
thank you
ron
Jan 08, 2011 | Jamo SUB300BA SUB 300 Powered Subwoofer...
Jamo i300 speakers are dead.
There is peobably a fuse located on the back. Your speaekers are probably okay. If anything fried inside, it is probably the output transistors.
Feb 02, 2009 | Jamo A 102 HCS 5 System
JAMO SUB 650
hi
since it is a powered speaker, probably it just needs a sound signal which you can get from the headphone socket. please double check with someone else.
May 26, 2008 | Jamo D 4SUB Subwoofer
I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Mar 15, 2008 | Jamo 1060 SW Speaker
Jamo 250
hi, there must be this LINE IN socket (ur so called Hole), then on the onkyo, there must be this sub-line out socket, plug one end of the RC socket to the sub out of onkyo , and other to the line in of the sub, its all to do wirth its appropriate inputs and outputs,let me know
Jan 11, 2008 | Jamo D 4SUB Subwoofer
57 people viewed this question
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
