Televison & Video Logo
Question about Vizio Televison & Video
I have a 65' Vizio tv 2 years old Model # D65u-D2....the issue i have is the tv turns on but after anywere between 10 and 30 minutes the screen goes black but I still have audio any suggestions?
Posted by rick cheatham on
Abctay.com
    Master:
  • Vizio Master
  • 372 Answers
There is something wrong with the backlight circuit.I guess you can'nt fix it.ask a TV repairman,he will tell you how to fix it.Or if you want need tv parts ,link this website: Abctay com China Wholesale Wholesale Electronics Gadgets tv parts power...
Posted on Sep 05, 2018
5 Related Answers
Anonymous
SOURCE: Screen goes black, still have audio
I first changed the 220uf capacitor with no luck. I flipped the BURN switch to on and the set has been working great for a week now. Daughter left it on for about 20 hours overnight with no problem. Anybody have an idea what those 4 tiny switches are for? I have heard these type of switches called "dip switches". They are tiny white switches in a yellow block on the lower left side of the upper circuit board. The top one was labled 40", the next one down was labled 46", the 3rd one was 4 letters "EW" something I think, and then the bottom one was labled "BURN".
Posted on Aug 12, 2009
Anonymous
  • 3917 Answers
SOURCE: TV turns on ,VIZIO emblem lights up,then the VIZIO
Hi
It sounds like bad power supply capacitors. Take it apart and take a look and replace them. Also try this:- unplug the TV from the wall and hold down the power button for a minute and then plug the TV back in outlet and turn on.If the power is good, I suspect the issue might actually lie in the mainboard.
You can check this. If you have a multimeter you can check between ground (any metal of the case) and one of the wires coming from the power supply is supplying 5VDC standby. If it is and the indicator light isn't on, the mainboard is likely at fault.
If there is no 5VDC standby voltage being supplied from the power supply, the fault is in the supply.
Maybe the mainboard has a short that is killing the power supply or the inverters.You have to buy a replacement.
Please get back to us if you have further query or else please accept this "particular" solution.
Thanks for contacting fixya.com
Posted on Sep 19, 2011
SD Tech
SD Tech
  • 14553 Answers
SOURCE: 62MX195 screen goes momentarily black a few times per minute
may or may not be lamp: lamp has a average life of 2,000 hours which is about 2 years for most people.
Posted on Apr 18, 2012
mosekha
Moses Isaosi
  • 23 Answers
SOURCE: I have a Vizio VP503 HDTV. The screen goes black but the audio continues. I turn it off wait a few minutes and it is good for another 30-40 minutes before it repeats. suggestions?
When metals heat ,they expand and in the process form what we call dj's (dry joints). Check cold cathode fluorescent lamp inverter board for dry joints, resolder if there are any and you will have your problem fixed. But if you have sound with backlight but no picture, then something is wrong on your data display channel card. which might require you to replace the whole board
Posted on Jul 05, 2016
Larry
  • 4627 Answers
SOURCE: vizio 65in Model D65u-D2 I have a black screen with sound.think it may be led driver but i can change format to small and take off HD channel and it will stay on. would this still be the led driver?
Most likely not...sounds like a software issue to me
Posted on Dec 13, 2017
2helpful
Vizio D65u-d2 Backlight not working after replacing 2 LED strips?
You should be able to replace just the bad LED strips however with as much work as it is to get the set apart and back together I always replace all them as other strips generally fail in time. Did they all light up after you replaced the bad ones before you put it back together? This model set has local dimming so servicing it is a bit more complex, you could have a bad backlight driver but that board seldom gives issues, also you could have main or power board issues as power for the backlight driver comes from the power board or you could have main issues as it's the signal from there that turns on each strip.
Hi, I have Vizio d65u d2 Screen goes black after 3 minutes, I change power board supply and led board, but still same problem
Hello
Make sure the connectors are snugly in place and that the set in not i a position that stress the boards, reset all settings then
change the picture mode to standard and auto brightness to medium
Good Luck
Mr.Mike
I have a vizio d65u-d2 i turn it on and after 5 minutes the screen goes black it still has sound though any ideas as to qhat it could be?
Let us know what exact model this is. It is possible that this is caused by a bad power board which then causes your backlight to turn off, but can also be a T-con or main board issue. Let us know if only your picture turns off or if you lose sound as well and if the picture comes back on. You do want to try to reset your TV. Unplug it and push and hold the power button for about 30sec-1min then plug it in while holding the power button depressed. If that does not help, remove the back of your set and post some good images of your boards with your question. That way we can see what you see and could try to assist you further.
Top Vizio Televison & Video Experts
Marvin
Marvin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
