Makes crazy noise when spins. Something hits very hard but still works. Any idea what is that just started all of the sadden. THNX
SOURCE: Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
SOURCE: Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
SOURCE: dryer makes squeaking noise
If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, open dryer door, remove screws going up into top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side.
SOURCE: Spin cycles doesn't work, tub full of water
i have a similiar problem, mines fills up with water, and the three orange lights start beeping when it suppose to be agitating. please help
SOURCE: 2002 Nissan Maxima Heat/ AC Blower Noise
i have the same problem on 2000 nissan maxima ... where do you squirt the WD 40?
