Question about GE 25861GE3 Twin Cordless Phone
How to set date and time?
Does anyone have an owners manual for this? I need to set the date and time....lost manual and can't find one online!!!
Posted by forthegirls on
Anonymous
If you are trying to set the date and time for the answering machine the buttons to do that with are on the right side of the main phone base.
Posted on Mar 23, 2008
How do you set the time and date on my 85 oldsmobile regency brougham
You may need to buy a used owner's manual online for this.
I think you press time/date, then press Reset, then put the correct time and date in, then press time/date again.
Sep 03, 2015 | Oldsmobile Cars & Trucks
I have Equity Time Insta-Set Model 40018. I lost the directions about how to set it. How do I get the directions? Are they available online?
Model 40018: You do not need the 9-volt battery to operate this clock.
NO TIME DISPLAYED WHEN PLUGGED INTO AC POWER:
If the display is blank when plugged into the AC outlet, unplug from AC power and remove the Insta-Set battery (lithium button cell), then plug into AC power again and manually set the Time and Date.
  • HOUR: Press and hold the DST SET button for 7 seconds until the 12:00 flashes. Use the PLUS and MINUS buttons to set the Hour. Press and release the DST button to move to the Minutes.
  • MINUTES: The Minutes will be flashing. Use the PLUS and MINUS buttons to set the Minutes. Press and release the DST SET button to move to the Month.
  • MONTH:The Month will be flashing. Use the PLUS and MINUS buttons to set the Month. Press and release the DST SET button to move to the Date.
  • DATE: TheDate will be flashing. Use the PLUS and MINUS buttons to set the Date. Press and release the DST SET button to move to the Year.
  • YEAR: The Minutes will be flashing. Use the PLUS and MINUS buttons to set the Year. Press and release the DST SET button to secure the setting in the memory.
After completing the manual set for time and date, insert a fresh Insta-Set button cell battery and the settings will automatically be stored in the clock.
Jan 31, 2015 | Audio Players & Recorders
Setting up date and time
You can download the manual from http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=162
Jan 27, 2010 | AT&T 1717 Digital Answering Machine
Need manual for Southwestern Bell Freedom Phone FM 891B
The date and time are set when you receive the first call after plugging in your phone.I have the owners manual if you need more help.
Sep 17, 2009 | Southwestern Bell FT372 Corded Phone
How to set the date and time
Below are instructions for changing the Date and Time for your machine. At the end, you will find a link for the owners manual for the 2060. Best of luck.
Greg
Entering the Date and Time
Follow these steps to enter the date and time.
1. Open One-Touch Speed Dial panel.
2. Press Data Registration.
3. Press Set twice.
4. Press Set again, then use the numeric buttons to type in the correct
date and time.
Use the MM/DD/YY format for the date and use the 24-hour
clock for the time, so 2:30 p.m. would be 14:30, for example.
5. Press Set to save the date and time.
6. Press Stop to return to standby mode.
http://aaabusinesssystems.com/pdf/_2060_Users_Guide.pdf
May 29, 2009 | Canon LaserClass 2060 Fax
Reset date and time on my Southwestern Bell GH5810
Press+hold MEM. "SET LANGUAGE" should be there. Press MEM , and "AREA CODE". Press MEM and "Set T/P". Press MEM "Ringer ON". Press MEM and "DATE/TIME". The "hour" will blink, type the number to set it. Then minutes Then "AM/PM". To swap it press any key, or "^" to skip. Then month. Then day. Then MEM to get to "CONTRAST". Then MEM to get out totally.
Dec 03, 2007 | Southwestern Bell GH5810 Cordless Phone
Canon p23-DH V
Slide the on/off switch all the way to the left to the "Rate Set" position. Now enter the appropriate tax rate. When entered, slide the switch to the desired "On" or "Print" position and CE/C before your first calculation. You should now be all set to go.
Oct 10, 2007 | Canon P23-DH Calculator
Set time and date
Hi. I found a link to your owners manual. It is in pdf format.. http://www.audiovox.com/manuals/owners/MP5610_122304_final.pdf (dont be thrown off audiovox and jensen are one in the same company) PLEASE RATE ME 5 stars when you are done!!! ---ampman
Aug 27, 2007 | Jensen MP5610 CD Player
Time & Date Stamp
The date and time (and a lot more) are stored with every image. Any photo printing program should have an option for printing the date and time on the picture (or in the margin or even on the back if the printer is two-sided).
Jul 07, 2007 | Olympus Camedia C-3030 Zoom Digital Camera
GE 25861GE3 Twin Cordless Phone Logo
228 people viewed this question
Top GE Lands Phones Experts
martin hogg
Bruce Robin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
