Possible source of instructions on Timex site using the number on the back of the watch.
https://support.casio.com/en/manual/manuallist.php?cid=009
Timepieces Watches
http://www.fixya.com/support/t25592449-change_casio_wr100m_from_military_time
SOURCE: setting day and date
To sync the correct 12 hour with your day you need to set the date to the day before (if today is Wed 21, then make sure the day window reads Tues 20). Then spin the analog hands until the the date window turns to Wed 21. At this point your watch is reading 12 AM (midnight). Then keep turning to set the correct time. If it is 9 am then stop the hands the first time you hit the 9 marker. If it is 9pm, then keep turning until the SECOND TIME your hour hand meets the 9 marker. This is now set for 9 pm. The day (Mon thru Sun) sometimes needs to be set seperately from the day; it may take a couple of tries but use the directions above and patience and you will achieve your goal.
That's how you do it. If you need more clarification let me know.
SOURCE: I have a perpetual calendar watch and no matter
Usually these kind of watches does not indicate if you are on PM or AM.
My hunch is that when you set the time and it goes pass 12AM the watch thinks that it's just 12PM so it does not change the day. Technically you are 12 hours behind.
To set things right try moving the dial until the hand reaches full circle and it changes the date.
once it does it will give you a hint wether you're on AM or PM so you can set it back to the correct date and time.
Hope this helps!
SOURCE: how to set time and date on Nike Oregon Square Digital Blue Fox Watch WA0036
click the link below for instructions
http://www.nike.com/timing/extranet/product/os_square_digital/sqrdigi_manual_eng.pdf
