SOURCE: service code on Panasonic Copier
Your sep/trans corona is either shorting out,or the wire is broken. AFTER FIX IS DONE IT WILL AUTOMATICALY RESET CODE.
SOURCE: I have a Pitney Bowes (Panasonic) DL355 copier
hi there,
the error code means The paper lift motors for tray 3 & 4 are not working correctly, usually caused by broken gear in lift unit.
You can check for something as simple as paper jammed between the back of the paper cassette and lift assy. Although the gear tends to get twisted when ledger paper is present(and commonly in the bottom cassette).
make sure that the pins in the harness are connected all the way? I would also try reseeding the connectors just to be safe.
1) DZLF000484 (COUPLER GEAR)
2) FFPHQ0063 (COUPLER)
3) FFPFJ00441 (STOPPER RING - in case this was lost when te coupler broke)
4) DZKM000043 (LIFT PLATE - unless you can bend it back to it's original state.)
otherwise you may have a bad system console board.
according to a thread i went to the odds of both motors going bad at the same time are very slim.
hope this helps!
SOURCE: for a copier,with the model no. giving ''u'' letter is meaning what?
If you model of your copier is like AR-M455U. Then the U means it is not a networkable machine. You can't connect it to a network unless you buy and install the network option. Which is different for all models.
Add Card
