Question about Sony Cameras
SOURCE: manual and software cd for sony cybershot dsc-t700
Hi
Please download the user manual for your Sony Cybershot DSC-T700 from this link
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/DSC-T700-_E
The drivers for your camera could be downloaded from here. Need to select your OS from the pull down menu before downloading
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DSCT700
That is all you need to connect your camera to your PC.
If you would like to edit your pictures, you need to buy that software
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jun 26, 2009
SOURCE: sony Cybershot DSC-W150,screen reads turn power on and off again
You may not believe this and I hope you haven't spent a lot of money fixing your problem. I read that some people had a different error message coming up on their Sony Cybershot DSC-W150's and in order to fix it, they literally banged the lens against their knee while the lens was out and it re-focused and the error message disappeared. I tried this while my camera was doing exactly what you described above AND IT WORKED!!!!!!!!!!!!!!!!!!!!
After 2 or 3 firm blows, my LCD screen came up and focused. I can't believe it myself, but I was just desperate enough to try it and VOILA!
Good luck!!
Posted on Aug 30, 2009
SOURCE: SONY CYBERSHOT DSC T2 keep shaking?
This is a known issue with the DSC-T20 Cameras.
Check this link for more information and get it serviced to resolve the issue.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT20&news_id=269
NOTE: Confirm the model # of the Camera whether it is DSC-T20 or DSC-T2.
Good Luck!!!!!!!!!!
Posted on Oct 09, 2009
SOURCE: Cyber-shot DSC-T70 Digital Camera: My Sony Cybershot dsct70 touch screen vibrates whe...
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
Posted on May 26, 2010
