For some Electrolux models, icluding the EDC2086PDW, the child lock (control panel lock) is toggled on and off by pressing and holding the Time and Wool Load touch pads together. Hold the buttons until you hear the beep or the indicator light goes off. (The dryer needs to be on for this to work.) On the EDH3498RDL, the two buttons are the Time and Anti-Crease. On both of these models, the two buttons are the left-most pair of a set of four buttons to the right of the LCD screen.
The much newer EDH3498RDL uses a different Control Lock method. Press the Options button repeatedly until the LED next to Lock is let. Then press the adjacent Set button. The Lock option is in the column just to the left of the Start button.
Please add a comment with the model number of your dryer to get the procedure for your unit. I hope this helps.
SOURCE: Child lock is stuck on and athe dryer will not
HI!!
Child Lock can be used to prevent your children from undesirable use on control panel while the
dryer is running. When Child Lock is enabled, all the button will be locked and Child Lock glows.
To lock Child Lock, Press and hold Rack Dry for 3 seconds, A single beep tone is heard and CL is
displayed on the status window. To unlock Child Lock, press and hold Rack Dry for
3 seconds again.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
SOURCE: turn off child lock
If you post the model number of your machine, I can get you the unlock information.
SOURCE: HOW TO TURN OFF CHILD LOCK FOR ELECTROLUX AUTOMATIC WASHING MACHING
Go into the settings menu and find the lock setting put in the code usually 0000 and then unlock.
