We have it hooked to antenna tv
SOURCE: HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
SOURCE: Mitsubishi 55" - Stretches screen
on the frount you should have ch up , ch down,
same for volume , and menu. press menu
and scroll down to VIDEO or SET UP
try one of thoes sub menu will have FORMAT
4:3 - 16:9 seting its a little differant on
on same make diferant models , you may
have to do a little hunting to find the setting
SOURCE: Wii and Mitsubishi 52" projection TV
Yes. You would need to use the analog or Component connections.
If the back ground of the video does not move or rarely moves, you will run the risk of burn in on one or more of the CRT's.
I hope this helps,
Sky Assoc
SOURCE: I have an older model hitachi tv and im trying to
How old is it? Is it an analog set?. There are no more analog broadcasts. You need a digital to analog converter box to watch the digital broadcasts. Ask your neighbors how they receive broadcasts.
Of course it is possible there are no broadcasts in your area. I live in the mountains of New York and we require satellite or cable to watch anything.
Check and replace its tuner. Before doing that, try a reset to your TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done./
