Question about Dryers
My whirl pool supreme dryer turns but no heat where are the 2 circlets locateed in dryer
Posted by Jean Fitch on
Zinhle Mteshana
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 51 Answers
In front of the pool
Posted on Sep 02, 2018
5 Related Answers
Anonymous
  • 770 Answers
SOURCE: whirl pool dryer
L1 Hot= Left terminal (Red Wire) ...... L2 Hot= Right side terminal (Black Wire) .......... Netural = Center terminal (White Wire) .................. Ground is Green connect to the cabniet of the unit and remove the connection strap from the center terminal on thje dryer wiring block..
Posted on Feb 23, 2008
Anonymous
  • 2712 Answers
SOURCE: Whirl Pool Dryer Model # LGR7646DQO
If your dryer doesn't heat, check these:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to. Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Sep 29, 2008
Anonymous
  • 26 Answers
SOURCE: whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Posted on Dec 20, 2008
onthejob5130
onthethejob1
  • 640 Answers
SOURCE: whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Posted on Dec 25, 2008
woobie dog
woobie dog
  • 1273 Answers
SOURCE: need to find schematic for
Hello. W/D here.
Here's something better; exploded diagrams, parts lists, and manuals. Enjoy.
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dryer-Parts/Model-LER7620LW0/1198/0151200?searchedModel=LER7620LWo&blt=11
Best regards, --W/D--
Posted on Apr 05, 2011
I replaced heating unit in whirl pool supreme 7 cycle and there is still no heat any ideas
You will need to check the thermostats on the unit. What is the model number of your unit?
Apr 25, 2012 | Whirlpool Dryers
Wed8300swo whirl pool dryer replace motor you set all setting push start nothing comes on but the heat
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 08, 2010 | Whirlpool Dryers
Need a heating element for a whirl pool dyer
try REPAIR CLINIC .com can order from them!
Dec 31, 2009 | Whirlpool GEW9250 Electric Dryer
Sometimes dryer will heat right, next time it won't
You more than likely have a buildup of lint in the vent hose. Even what looks like not much lint in there can cause the dryer to have issues drying the clothes. Clear the hose out really well, take it outside and shake it all out, then hook it back up and give it a shot. If that doesnt work you may have a bad thermal fuse which regulates the dryer temperature and you will need to have it replaced.
Dec 14, 2009 | Whirlpool Dryers
Dryer does not go past wet cycle
if your vent hose is clogged, your element most likely burnt open
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirl pool dryer does not dry?
coil never gets power usually a sign that you have a blown thermal fuse , small white 2in' fuse located behind rear panel, there should be a wire diagram behind the console, few screws acrosss the back
Oct 30, 2008 | Dryers
I need to replace the belt in my ge dryer. how do i get the back off to get to the inside. we have unscrewed every screw and it doesn't seem to want to come off.
whirl pool and most other manufacturesdryers are front serviceable for belts depending on dryer top pops up (2 srews under filter on whirpool top filter dryers )2 front clips push those in top lifts ..2 screws on inside front panle take out front lifts off
Apr 26, 2008 | Dryers
Drying time taking to long
By the way your describing the problem the thermostats are getting weak on the elements replace the operating and the high limit t-stats.
Jan 03, 2008 | Dryers
Whirl pool Dryer not staying hot
you need to have your gas valve coils replaced good luck
May 27, 2007 | Whirlpool LGR4634J Gas Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
