Question about JVC Car Audio & Video
Taking a flying guess the wire could have two possible functions - either providing the radio with additional illumination when the vehicle lights are on or if the illumination is permanent it could dim the display, etc. when the lights are switched on.
Posted on Sep 02, 2018
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
SOURCE: need wiring diagram for kd-shx700
Hi There, if you click on the link you'll find a wiring diagram...
http://resources.jvc.com/Resources/00/00/95/LVT1158-002A.pdf
Rich...
Posted on Aug 16, 2009
SOURCE: I have a ford factory wiring plug with 5 wires, I
If you are talking about the trailer brake pigtail under the dash, the brown wire is for the illumination on the brake controller, if applicable.
My reese hand held controller did not use this, so I just blind end tapped it into the harness.
If your brake controller does not have background illumination, then you don't need the brown wire.
Sounds like the controller is similar.
Posted on Nov 16, 2009
Testimonial: "I have to tell you, I was having a brain fart when I posted that problem and I did excactly what you did after I thought about it. Thanks"
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Posted on Jan 25, 2010
SOURCE: I just purchased a JVC KD-S16 CD Player and I can't install it.
Get an adaptor wiring harness. It plugs directly into the plug in the truck. The wires are all labeled and you won't have to hack up the wiring in the truck. You can get the adaptor whereever they sell car stereos.
Posted on Apr 01, 2010
Testimonial: "Thanks much, only added more stress after the first one got stolen to get home with the new one and couldn't attach it. Very helpful indeed."
Sep 22, 2017 | Car Audio & Video
Feb 05, 2012 | JVC KD-PDR30 Car CD/ MP3 Player
Dec 27, 2010 | JVC AM FM CD DET FACE CAR STEREO
Apr 01, 2010 | Audio Players & Recorders
Nov 22, 2009 | JVC KD-G340 Car CD/ MP3 Player
Jun 12, 2009 | JVC KD-S640 CD Player
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
Sep 17, 2008 | JVC KD-G230 CD Player
Feb 06, 2008 | JVC KD-S5050 CD Player
May 26, 2007 | JVC KD-SX650 CD Player
74 people viewed this question
