Question about Electrical Supplies
I have an On an 4000 in my rv. It runs but I have a steady fault light. It says to check the circuit breaker in the coach or the breaker on the genset. Where is that located?
Posted by Gary Blake on
2 Related Answers
Anonymous
  • 26 Answers
SOURCE: onan genset generator in rv is running but no
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
Posted on Aug 29, 2009
motor1258
Mike Butler
  • 6674 Answers
SOURCE: Genset starts and runs fine but the 30 Amp circuit
What about when you have it powering the motorhome, without AC on, does it trip then? Do you have anyone you know with a multimeter and knows how to use it? How about buying a plug in voltage meter at a hardware store as a good start. You simply plug it in to a receptacle in your motorhome and it will tell you the incoming voltage and they are not very expensive. That will help diagnose generator problem.
Posted on Jul 23, 2010
Rv slide out
Check the switch inside the coach. Usually either the switch or the breaker fails.
Aug 16, 2014 | Fleetwood 2009 Tioga Ranger 31N
How do I locate the charging system wires at the converter ?
Should have the basic schematic in your owner's manual. If not, contact the mfg and see if you can download one or have it mailed.
No luck? Google it. If persistent enough, you can find one.
Jul 30, 2014 | Holiday Rambler 2010 Mintaro 26RKS
I HAVE A 5.0BGE ONAN GEN SET IN MY RV IT RUNS BUT THERE IS NO ELECTRICAL POWER TO RV ALL FUSES AND BREAKERS OK. ANY HELP APPRECIATED
Possible solution: if it's been sitting idle for some time, you might need to flash the windings. see this link:
http://www.endtimesreport.com/dead_gen.html
If you're uncomfortable doing it yourself, your Onan dealer can do it in 10 minutes.
Don't forget to check the circuit breaker on the generator itself!
Sep 01, 2011 | Watts Onan Portable Generator - 4000 ,...
No 110 power inside coach when pluged in to shore power.Have checked everything I know and still no outlet power. I do know alot about repairing things but have not hit on it here. Power will come to the...
I take it you metered for voltage at the shore power outlet, and at the cord end itself where it plugs into the RV, is there a buck/boost transformer..if so does it have a breaker, are there fuses at the inlet receptacle. Are all GFI outlet breakers in the RV checked for normal position?
Jun 12, 2011 | Electronics - Others
My rv's A/C will not turn on. When I was camping I had my A/C running and when I tird to turn it off with my remote the system would not respond. So, I went to the breaker and manually shut it off. The...
first turn the power on to the unit and taking a pencil manually activate the contactor switch by pushing the contactor swith in. (this is the switch that the power feeds to the unit from the supply) if the unit activates and runs then you problem would be your low voltage control(transformer) if not then the problem will be in the circuit board. Good Luck on repairs
Dave
Sep 01, 2009 | Heating & Cooling
Onan genset generator in rv is running but no power to rv...circuit breaker has been checked and main breaker in rv has been checked still no power
Aug 29, 2009 | Watts Onan Portable Generator - 4000 ,...
Ac Problems
You must have too many things running on that circuit. Check your connection to the power box.Loose connection on the receptacle can cause the breaker to trip or too many things running on the same circuit. If the breaker is old it might need to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 10, 2009 | Dometic Rooftop RV Air Conditioner
Rm2807 rv refrigerator gas works but the a/c is not working
Check the 110 volt wire for flaws. Take a volt meter and check the recep that the fridge plugs into for power, should be 110 volts or so. +/- 10%. If you have power at the recep problem is in the fridge chord or circuit board fuse or circuit board. Also check the 110 volt breaker in the coach at the service panel.
Mar 29, 2009 | Dometic RM2852 Refrigerator
Onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Mar 02, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
95 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
