Televison & Video Logo
Question about Sampo Televison & Video
I have a 15000 BTU Sampo air conditioner. The remote control doesn't open the unit. The remote control works fine!!New batterries and all!!
What can I do? The Sampo company is not in Greece anymore! Any ideas what the problem might be?
Posted by roula s on
5 Related Answers
Anonymous
  • 86 Answers
SOURCE: Westpoint split air conditoner remote contol unit
1.model no.
2.capacity of yr unit.
3 brand name.
mailme [email protected]
i can send to u
Posted on Mar 16, 2008
Anonymous
  • 3422 Answers
SOURCE: air conditioner window unit {Hampton Bay}
You can get the parts from the below sites:
www.searspartsdirect.com
www.partstore.com
If you need anymore help let me know.Please don't forget to rate or accept the previous premium solution.
Posted on Jun 22, 2008
Anonymous
SOURCE: Kenmore 18,000 btu Air Conditioner model # 75180 - Condensor Problem
HI , LISTEN MY AIR CONDITIONER DOES NOT START. CORD,THE POWER-TEMP CARD OR WHAT ELSE IT HAPPENED IN A LIGHT OUTIGE. THANKYOU. IT A KENMORE 18,000
Posted on Oct 20, 2008
bobotfel
Felizardo Erilla
  • 241 Answers
SOURCE: Remote is working- but unit won't turn on
check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Check for reset or rst button in your remote control and push it to reset and test it in your unit. If wont work means either the receiver board or mean board is defective.You need a qualified tech. for this problem. For the mean time you can use manual button to operate the unit.
Posted on Jan 31, 2009
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
SOURCE: how many amps will a 15000 btu ac unit pull at
15,000 BTU stating current 18 to 20 amphs. And running amphs will be around 6.5 to 7 amphs.
Posted on Dec 13, 2010
Suburban air conditioning
googled:
"suburban air conditioner 15000-48254C966" and got specs right here:
http://www.adventurerv.net/coleman-15000-btu-roof-air-conditioner-top-unit-p-1332.html
good luck.
4helpful
I have a dometic rv unit 15000 btu what is the amp draw?
For an RV 15000 BTU air conditioner the size being maximum for 115 volts ac you will need to have a independent circuit breaker for it only and rated at 20 amps. The average amps depends on serveral factors like actual supply voltage somtimes 110 to 120 volts and wire size and length feeding the air conditioner. To answer your question the average Amps will be near 13 Amps. Click Here=>
Dometic RV Air Conditioner Installation Manual and Specifications
Click here for a photo of the Electrical Spects.=>
Dometic_RV_Air_Conditioner_Electrical_Specifications
If you have any questions I will be here to answer them for you, Thanks, Sea Breeze
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Ge window unit runs fine but there is a rachety sound
One way to reduce the sound it makes is by placing styropor insulation around the unit. Although a better way is to have it inspected by technician to check the blower balance and correct it.
I hope this helps.
3helpful
Duo-them 15000 BTU roof air
Is this a non-ducted system with dials to turn on it, or is it controlled by a wall thermostat ?
Top Sampo Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Sampo Televison and Video Expert? Answer questions, earn points and help others
