Question about Camping, Backpacking & Hiking
I need a new battery holder for my Defiant 5" flashlight. It is Part #C2912.
Posted by Terra V on
Tom Chichester
    Top Expert:
  • Camping, Bac... Master
  • 55,667 Answers
Fixya does not sell Defiant parts.
Posted on Sep 02, 2018
1 Related Answer
mccluskey1
NOEL
  • 8546 Answers
SOURCE: How to change batteries in defiant 51 flashlight hd13q413?
hi mattie.
not sure if this link will help you out but have a look.
How to change batteries in defiant 51 flashlight hd13q413 Google Search
Posted on Nov 01, 2017
I have a defiant flashlight that has a flat chip type bulb. I need to get one for my flashlight
look up your model online or go to defiant site for location of distributor or replacement parts
Nov 12, 2016 | Camping, Backpacking & Hiking
Can I buy a battery holder or frame for my NEBO Select flashlight?? My grandson dropped mine in the lake while changing batteries.
Given the cost and availability of those lights vs the expense for the battery carrier, you should just get a new light.
Feb 20, 2016 | Nebo Redline Select 310 Lumen Flashlight...
Where Can I find batteries for defiant
It's a special premade pack so I don't think you can find a direct replacement however it does appear to be 6xAA batteries. Must be series parallel. 3 in series, two sets of 3 in parallel. If you are handy with a soldering iron you could replace it by making a new pack using NiMH AA cells.
Oct 07, 2014 | Camping, Backpacking & Hiking
Model 7000 slide not working
I have a Defiant 7000 flashlight and took a look. When the light is closed, the top of the battery door (1) is right at the lip (2) that keeps the light from over extending. I couldn't get mine to close with the cover loose, but if you did you could carefully drill a hole (3) in the outer casing to see and push the battery door back into place. You could also remove the two philips screws under the rotating magnets on the base and maybe push hard enough to force the top out?
Feb 22, 2014 | Defiant Camping, Backpacking & Hiking
My flashlight will not turn off
This is what i did to make it work (by pure guesswork).
1. take the battery holder thing out.
2. see black arrow on side of battery holder, that needs to point toward the led end when you insert it.
3. Look at the end of the battery holder, at the end that will go in first when you insert it. On each end there is that silver metal circle that has some silver metal extensions that go straight across the bottom.
4. look into the flashlight toward the led end. See the green circular circuit board thing. You'll see that equally around that circular base, there are 4 little squares of metal right to the edge of the green base, equidistant around the green circle. Carefully insert the battery holder with the silver metal strip on the holder lined up so each end of that strip will touch one of the 4 little square metal things on the edge of the green circuit board. The goal is that when the battery holder is all the way in, the two metal extensions coming out from the little circular metal piece on the end of the battery holder will each touch one of the little square metal pieces on the green base.
5. Screw on the lid and click the end to turn on the light. I tried this two times and both times it worked. If it doesn't turn on you might want to try to reinsert it again and get it more carefully lined up.
Good luck.
Apr 28, 2013 | Emerson 9X Power LED Flashlight
Defiant headlamp; where's the tab to be removed?
If you are talking about a shipping tab that prevents the batteries from discharging during shipping, look inside the battery compartment.
There should be a plastic, or cardboard tab, that prevents one of the battery ends from make contact with the flashlight. Just pull the tab to remove it.
Mar 24, 2013 | Defiant Headlamps, Lanterns & Spotlights:...
I need to find a ac/dc charger for a Defiant Flashlight Model 800-2701D Can you help??
This flashlight is sold by Home Depot, and it is possible that you might be able to find a name-brand exact replacement charger there. However, you almost certainly can find a replacement charger elsewhere for less money.
Looking at a picture of the light and its power adapter, it appears that the light has a standard barrel charging port. A dollar store or "Dollar Plus" store is likely to sell inexpensive multi-voltage universal chargers that will fit this light and get you back in business for under $5.
When fitting a non-OEM charger to your light, make sure that you've set proper polarity and input voltage for your device, or else you may damage it in charging. Many devices specify voltage and polarity right on the device, molded into the case or on a small sticker. That makes this process super-easy. Otherwise, you may have to head down to a Home Depot and peek at one of these lights in its box to read the voltage output off the stock charger. The odds are pretty good that it'll be putting out 12 volts, but I won't guarantee that by any means--input may be 6v or even 4.5 volts, though those are much less common in lights of this type.
Dec 16, 2012 | Defiant Camping, Backpacking & Hiking
Camping, Backpacking & Hiking Logo
327 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
Kardoc
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
