SOURCE: i want to know how to recieve the fax conformation
Hi va707ejo,
Press Setup and select Print report.Then select fax confirmation and choose the option which yiu would like..
Thank U
SOURCE: HP Laser Jet 3300 constant noise
I had the same problem. After updating a hp firmware, so far so good. The noise is gone.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=66367&prodTypeId=18972&prodSeriesId
=66359&swLang=8&taskId=135&swEnvOID=54
That is the link for the 3330. It is under the downloads section and is at the bottom. They refer to it as firmware
SOURCE: i have HP Office JEt
you want others in your network to be able to use your printer for faxes as well as printing?
go to your control panel... find the printer and faxes option... double click it. select the printer you want to share... right click it and select share (you can also select properties and then go to the sharing tab) and select to share this printer.
the option to share over a network must be installed (it probably is) but if you have any doubts... right click on your network connection and you should see something there regarding file and printer sharing.
hope that helps, & let me know if you need any more info!
bru*
SOURCE: HP Office jet 7210 All in One. When I feed paper
Lean the rollers in the automatic document feeder (ADF)
To clear the "scanner error" message do a
Perform a partial reset
If a partial reset did not work do the following:
Perform a semi-full reset
CAUTION:
Performing a semi-full reset deletes any saved phone numbers on the product.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: I have a Hp Office Jet Pro L7590 All In One. The
Check the cyan ink supply line for air bubbles. These printers work off negative pressure between the print head and the ink supply. If there are bubbles in the line the negative pressure is disrupted and ink cannot flow through the print head.
