Question about Whirlpool Microwave Ovens
Whirlpool microwave keeps beeping
Keeps beeping for no reason
Posted by Luann Gappa on
5 Related Answers
robert landry
  • 96 Answers
SOURCE: Keeps beeping and shows F3 but keypad not working
Ya what the ????
Not shure what to tell you, first I would see if leaving unplug for a day would solve your problem, to me sound like main board is defective, also try by opening the door a closing it a couple of time, just in cass a switch is jam open.
Regards
bob
Posted on Jan 20, 2008
Anonymous
SOURCE: sylvania p70d20al-d5 microwave keeps beeping
I have the same problem with my microwave, the clock disappears and it says "enter" and "amt", I figured out it's the "beverage" button that is sticking. When I want to use it I just press "beverage" and then "reset" and just press them over and over until it stops. Usually it's on the first try, sometimes I have to press them a few times. Just don't do what I'm about to type though, I decided to get my razor knife and cut the button out carefully, I only cut the contacts on each side of the button, now no buttons work, I should have left it the way it was, at least I could use it that way.
Posted on Aug 08, 2009
Anonymous
  • 7 Answers
SOURCE: microwave is beeping, lock comes on, F2, just
F2 on a KitchenAid mike usually means a Keypad short. Beware if it is a KHMS155LSS, it can self start on its own with a KeyPad short. A real stunning defect.
Posted on Sep 09, 2009
Anonymous
SOURCE: Whirlpool Microwave Hood Combination MH3184XPS-0
Ours just started doing this exact same thing this past Friday - 12/11/09. What's going on? The cook power just starts beeping all by itself and going from 10 down to 1 over and over again. It may stop momentarily, but then starts again within a minute or so - it's constant until we unplug it. We plug it back in and within a few minutes it starts doing it again. What gives?
Posted on Dec 13, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Ge Microwave model JVM1650SH05 Error code F3.
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
The easiest and quickest way to repair this yourself (it's easy) is to order a new control panel frame, which comes with a new keypad.
It's part # WB07X10959 and you can get it for $92.50 plus shipping here.
You can also find helpful exploded view diagrams at that link.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Posted on Apr 24, 2010
36" KitchenAid microwave has been beeping for no reason. It's like someone is going to use it and it changes the display. Happened in the middle of the night. I cleared it, but it keeps happening
Erratic behavior sometimes occurs when microwaves are not plugged into grounded outlets. Make sure it is actually grounded. If so, you might have a defective control panel.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jul 18, 2016 | KitchenAid Microwave Ovens
My microwave seems to have a mind of its own it keeps wanting me to reset date and keeps beeping for no reason at random times
Most likely it's an electronic failure of the main circuit board. Although extremely unlikely, I have seen an oven or two that have had these symptoms that were caused by an insect walking on the back of the circuit board.
Apr 29, 2014 | KitchenAid KHMS2050SSS Microwave Oven
My whirlpool microwave m575 keeps beeping and displays A1. I cant use it can someone help me pls :)
please read your owner manual section troubleshooting. or consult your supplier microwave, for guarantee or tech service ONLINE.
God bless you
May 23, 2013 | Microwave Ovens
My Micro will not heat and it keeps beeping I can not get it to stop...
Its likely beeping as it is not heating, I presume light goes out when door closed and a turntable turns or not?
I can provide possible reasons for no heating etc.
Dec 21, 2012 | GE JES1142SF Microwave Oven
Kenmore 87002 keeps beeping every minute and I cannot set time. Keeps double beeping when I hit a button Tried unlocking it but still not working
The problem is in the keypad control board, replacement is the only option to remedy the situation, if you decide to repair, check the price of the part first.
Apr 29, 2012 | Kenmore 68361 Microwave Oven
Hello, I have the whirlpool microwave oven, Model ...
logic board needs replacement if it cannot be reset.
Jun 17, 2017 | Whirlpool MH3185XP Microwave Oven
Whirlpool Microwave Hood Combination MH3184XPS-0 (October 2004), for no reason at all, this morning keeps beeping and running the power setting down from 10 to 1, and just keeps doing it in rapid sequence....
Dec 08, 2009 | Whirlpool MH3184XP Microwave Oven
Microwave keeps beeping
that may be one of the setting it has like how a grandfather clock oes off every hour. could be the same thing. your going to need to read the manuel and see if that is a possible problem
Aug 07, 2009 | Microwave Ovens
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Sheldon Dedek
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
