The old memory card now full IS recognized by the scanner
if usb flash memory is working on other computer/laptop then do the following step.
Insert the usb flash memory.
Goto desktop, right-click my Computer, click Properties, click on Harware tab, click Device Manager button.
There should be yellow exclamation(!) sign showing Unknown Device
Right-click and select UnInstall.
Reboot your laptop
It should work.
SOURCE: samsung f300 says memory full
if you have any games that you dont use or rarely use try delete them then try find out if you have any service messages if you do try delete them too, if that dosen't work then you will have 2 options; contact your phone operator, or take your phone to be checked by/ unlocked by your nearest market stall.
SOURCE: new sd card says full
Check and make sure the SD card is in all the way, it should make a clicking sound when it's in all the way. I had this same problem with my Vivicam 8025. Hope this helps!
Testimonial: "you are right, thank you so much!"
SOURCE: My memory card is completely empty, all photos
You need to reset the file-numbering.
Turn mode-dial to Set and turn on the camera. Select Frame No. from the setup menu. Switch Frame No. to Renew. Press OK. Format the card (also from the Setup Menu) After formatting, select Frame No. againg and switch to Cont. File numbers will now start from 100.0001 again
SOURCE: I have a Kodak Easyshare C195 digital camera my
There should be an entry for "copy" in the camera menu.
