Washing Machines Logo
Question about Electrolux Washing Machines
Electrolux front loader washing machine no power at the socket
Posted by heather wilson on
5 Related Answers
Anonymous
SOURCE: Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
Posted on Nov 20, 2008
Anonymous
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
David
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
Anonymous
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
Posted on Jan 26, 2011
Anonymous
  • 6277 Answers
SOURCE: I have an Electrolux washing
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Please score this solution accordingly.
Thanks and good luck!
John C
Posted on Apr 10, 2011
Testimonial: "Thanks for your help we will try this and see how we go."
Electrolux washing machine drum not turning. Door will not unlock.
The most likely cause is a broken drive belt. You don't say if it is a front or top loader. For a top loader, pull the machine out, and drop the drain hose into a bucket to empty the machine. Tilt the machine against the wall. Have someone steady it and look underneath. You should see the motor and belt, although some are direct drive.
For a front loader, the belt is accessed from the rear of the machine.
1helpful
My Electrolux front loader machine is showing EHO in the display, it won't move off it no matter which program I try to display, can you please help me?
The power supply is failing and needs to be replaced but first try the steps provided in the link below. Washing machine displays error message EHO EH0
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
1helpful
How do i change fuse in my electrolux ewf 1087 front loader
There is no fuse in the machine. If you have no power to machine check the house fuse, it may have tripped.
My 7.5kg Electrolux Washing Machine whent bang and
your door lock has blown/short circuit turn power of disconnect plug take top of machine look down inside machine toward door lock and you shoud see the catch push hard with your finger and door will open be careful as there are some sharp edges in there.
Top Electrolux Washing Machines Experts
David Shaub
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
